Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 08-15-2004, 12:26 PM
donervogel donervogel is offline
Question 92 DeVille Starting Problems. HELP!!!!
I have a 92 DeVille with 131K. About two weeks ago, the car began to stall out a few times while driving, I would just throw it in neutral, then turn the car right back on without problems. Then I have an issue where the car won't turn on AT ALL! There is absolutely no power to the car, no lights or anything works. I can wait a few minutes than it starts up like nothing is wrong.
My mechanic told me it was the alternator and I spent $200.00 to replace that. The problem is back again just as bad as it was before the alternator. The battery is only about 2.5 months old. I checked the battery cables and they look fine and not corroded over.
What could this possibly be? I don't want to take it to Cadillac and be raped with labor charges. I can't afford to put much money in this car.
Please help!
Old 08-15-2004, 09:36 PM
Lightbulb Update ------
I tried to jump it and would not work. Still no power. As I was taking the cables off the positive terminal, power came back and started up.
1) I believe this needs new battery/terminal cable mounts
2) If the positive was a bit corroded, I think this would have cut the power to the alternator causing the car to stall
Does this sound like it makes sense?
HELP!
Old 08-18-2004, 12:34 AM
pbsfolks pbsfolks is offline
sounds like you tracked it down, Id replace both cables just to be sure, good luck
