Old 08-15-2004, 11:24 AM
Nstyle29's Avatar
Nstyle29 Nstyle29 is offline
Send a message via AIM to Nstyle29 Send a message via MSN to Nstyle29
Starting difficulty
At first i just thought it was the high altitude here in up in Summit County in the Rockies. But it seems to be getting worse. When i go to start my car in the morning it now takes a couple tries for it to finally keep started instead of rumbling. Then if i try and rev it up a lil it feels like it isn't getting any gas, as if something was blocking it...once it warms up though its fine!? Have any ideas?
Check out my 95 GS-T --> http://www.cardomain.com/id/nstyle29
Old 08-15-2004, 11:35 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Starting difficulty
my car does that all the time in the winter. it even does that sometimes in the summer. really not sure what causes it.
DSM geek
Old 08-15-2004, 11:40 AM
Nstyle29's Avatar
I have high mileage 111,000 so wonderin if it was fuel pump or something like that!? Not sure when that has ever been replaced
Old 08-15-2004, 06:51 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
dont all cars have crappy starts in places that are cold? In England my uncle's damn toyota siena and Astra had long crank times and reved like crap once initally started.
The daily driver. The weekend cruiser. The lazy shop hog.
Old 08-15-2004, 07:01 PM
coolguycooz coolguycooz is offline
If your car starts normaly durring the summer then its because its cold and the engine itself dosent run as well as it use to so it just be all of the old parts combined together trying to work when its cold. If it has the same problem when its hot then you might have a problem.
Old 08-16-2004, 07:27 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
I had this problem awhile back. What was happening was there was moisture in the sparkplug wells. When you fired the car up cold, the spark would jump to the water instead of the plug. After a minute or so the heat would evaporate the water and the car would run fine (except for the smell of gas). I seems as though the moisture would stay in there and recondense after the car would be turned off. I just bought new plug wires (my stock ones were shot), waited for a really dry day (low humidity) and drove the car around until it warmed up. Then I pulled the wires and left them out with the hood up (in the sun) for an hour or so. then put the new plug wires in. This might not be your problem but it worked for me.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
