Old 08-15-2004, 01:22 AM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
boost gauge
ok i got my boost gauge installed....now i have a small prob...it's telling me i'm pushing around 12psi of boost....this can't be possible considering i have no boost controller and a stock turbo...i made sure everything was connected correctly...what could be the problem?
thanks for the help
Old 08-15-2004, 01:25 AM
Killa_DSM's Avatar
Killa_DSM Killa_DSM is offline
Re: boost gauge
Its fine, mine is around 13 to 14 stock. I think most eclipse's are around 12 or 13.
"Life begins at 20psi"
97 Eclipse GST-X 5spd
PTE 5031e/pte 880cc/vr4 fuel pump/Devils Own Water injection 12gph nozzle/pre turbo meth injection/fmic 28x10.5x3.5/greddy type-s bov/12" K&N/FP intake/dsmlink/gm 3.3 bar/maft/blitz ebc/act 2600/act 6 puck/SS Clutch line/3" turboback.
Old 08-15-2004, 04:47 AM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: boost gauge
there is no problem
Old 08-15-2004, 11:05 AM
dsmodder dsmodder is offline
Send a message via AIM to dsmodder
Re: boost gauge
have you removed the extra "ring" in your wastegate soleniod 97gstspyder?
Old 08-15-2004, 05:16 PM
Re: boost gauge
nope i haven't removed anything...i was just wondering about this because i heared that stock t25's on our cars run 7-8psi stock i think...so you guys are sure this is normal? because even today i hit 500miles on my new clutch so i decided to get on it a little and my boost gauge jumped to 15 for a split second
Old 08-15-2004, 06:45 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
Re: boost gauge
its no problem. I posted something very similar to this thread a few weeks ago about creep. This will happen when you are not running a BC.
The daily driver. The weekend cruiser. The lazy shop hog.
Old 08-15-2004, 08:07 PM
Re: boost gauge
13-15 or wahtever is normal. a free mod you can do to get about 1 psi more is to remove a ring in your wastegate soleniod. heres the site http://eclipseworx.com/diy/bcs/bcs.html
Old 08-15-2004, 08:13 PM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Re: boost gauge
Yes, anywhere from 12-15 is perfectly normal.
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
Old 08-15-2004, 08:25 PM
AzN_SeNz8TIoN AzN_SeNz8TIoN is offline
Send a message via AIM to AzN_SeNz8TIoN
Re: boost gauge
If you bought it used also the person before could of had one, thats what happend to me. Normal my friends gs-t and my friends gsx run around 6 or 8 psi.
Old 08-15-2004, 08:48 PM
Re: boost gauge
Well your friend's cars must be fucked up, cause the lowest I've seen stock is 10
95 GSX
Old 08-15-2004, 08:58 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: boost gauge
where do you live. different elevations above sea level will boost different psi
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 08-15-2004, 09:02 PM
Well they must be atop Mt. Everest to only be boosting 6-8 psi! I could understand if it was 10psi +/- one or two, but 6-8?...
95 GSX
Old 08-16-2004, 02:21 AM
Re: boost gauge
i live in western pennsylvania...
Old 08-16-2004, 04:11 AM
JoeWagon's Avatar
Banned
Re: boost gauge
the WG actuator is a 7psi device. The stock BCS kicks it up to 14psi supposedly. If not, get a MBC and call it a day. You'll need it anyway.
Old 08-16-2004, 09:07 PM
Re: boost gauge
yeah i was wanting to get a MBC...what's a good one to get? also, i took that Boost Control Solenoid Restrictor Removal and i noticed a very slight difference in the sound of the blow off valve...makes a little more high pitched chirp after you hear the PSSSSSHT, ahh it's hard to explain but it's sounds cool...i'll try to get a recorder and record it then post it.
