S10 power mirror question
I would like to know if it is possible to get to the motor for the power mirror on my 95 S10 Blazer. I have power at the wiring harness to the mirror for both the left and right motor and the up down motor. The problem is down to a bad or broken wire or a bad motor. I would like to be able to apply power at the motor and check it out. I only need to get the mirror apart. Is it possible?
Thanks for your reply |
Re: S10 power mirror question
It's your switch.They are noted for it.
Thanks for the reply but the switch is brand new, Neither motor work with the old switch. I have power going to the mirror when the switch is operated. Both for up and down and left and right. Only left and right works. The problem is a bad motor or bad connection in the mirror housing.
I would like to avoid buying a new mirror if it is possible to fix this one |
I would like to avoid buying a new mirror if it is possible to fix this one. |
