Go Back   Automotive Forums Car Chat > Toyota > MR2/MR-S
Old 08-14-2004, 08:06 AM
andyeagle19 andyeagle19 is offline
Question Boost question?
Hello, I just have a quick question. I have a 92 mr2 turbo with a greddy profec b boost controller. When I set my boost, I was in 3rd and also did some runs in 4th gear, I finally fixed the problem I was having, but now when I start off from 1st, the boost only reaches 0.6bar, 2nd gear hits 0.8bar and from 3rd on, the boost is dead at 1.0bar. Is this expected from the ct26? I know it won't hit max boost levels in first gear, but should there be such a jump between gears. Thanks in advance for replies.
Sab
Old 08-15-2004, 01:52 AM
Re: Boost question?
any ideas?
Old 08-15-2004, 07:58 AM
JekylandHyde's Avatar
JekylandHyde JekylandHyde is offline
AF - Advisor
Re: Boost question?
... just one of the reasons I do not like the GReddy BC. The Blitz has no "learning modes" to set boost in.
I suspect that BC is limiting you.
Sponsorship: Amateur Motorsports <-- Get the book! - books are now available for shipment
Old 08-15-2004, 08:39 AM
So the Greddy Profec B has a "learning mode"? I wasn't aware of this.
Old 08-15-2004, 08:40 AM
AF - Advisor
Re: Boost question?
Isn't that how you are setting boost in 3rd gear?
**maybe I am wrong. I have a PRofecB years ago (1996!) ... and I recall having to do runs in 3rd gear so that it could "learn" the boost curve.
Old 08-15-2004, 09:56 AM
Re: Boost question?
I wasn't told anything about that. I do the runs in 3rd and 4th due to the added load on the engine as apposed to the lack of load in lower gears. Tuning boost in higher gears, I always thought was the most accurate way to do it. But if I am going about this the wrog way, just let me know. Thanks
Sab
Old 08-15-2004, 10:05 AM
AF - Advisor
Re: Boost question?
You are correct ... setting boost in 3rd or 4th is best.
What do you have to do on the Profec to set boost?
Old 08-15-2004, 10:31 AM
Re: Boost question?
It has 2 dials, 1 for low boost, 1 for high boost. You just push it in so it can be turned to set lower/higher boost. I have the low boost setting set to .5bar. A high boost setting of 1.0bar in 3rd-5th gears. 1st only goes to like .5 or .6 bar, and 2nd goes to around .6 or .7-ish. Still pulls good, but I would like to hit the set boost level in all gears even of it is just for a second! Thanks
Old 08-20-2004, 10:28 AM
Re: Boost question?
Anybody know about this controller?!?
Old 08-31-2004, 03:07 AM
MR2vsAMXbeast MR2vsAMXbeast is offline
Re: Boost question?
I think that I may have the same contoller as you do. The only thing mine has different from yours is a "Balance" dial. Im still trying to figure out how to set it.
Old 09-25-2004, 05:06 AM
Re: Boost question?
Any other ideas on this controller? BTW I do have 3 dials, just forgot about the mild/sharp dial! lol. Thanks for all replies.
Sab
