Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 08-13-2004, 12:35 PM
suprcut suprcut is offline
Blower motor
My blower motor ('96 Cutlass) is working in all switch positions, but it doesn't seem to be moving enough air. There's no blockage. Is there a resistor in the switch that may need replacing or is something else causing the problem?
Old 08-22-2004, 05:18 PM
DIY Mechanic DIY Mechanic is offline
The motor is very easy to remove.
Three screws and it will fall right out.
Before removing the fan motor, make sure there are no leaves under the hood where the intakes are (Under the wiper blades.).
Drop it and look into the compartment for leaves or any other obstruction. The squirrel cage could have come loose from the motor shaft. That is a fragile connection.
