Go Back   Automotive Forums Car Chat > Racing > Technical
Technical Discuss different strategies and theories of the racing aspect.
Old 08-13-2004, 12:34 PM
eclipsefan98 eclipsefan98 is offline
Send a message via AIM to eclipsefan98
bov question
i want to run a bov that vents to the atmosphere without dealing with the engine running like crap when it blows off. will replacing then MAS with a MAF or blow thru unit solve this problem? thanks guys
-1996 Eagle Talon
CAI, reprogramed ECU, NGK plugs, and ported head
-1972 Malibu
Mods: 409ci small block replaced the 6 cyl., posi. rear end, low gear ratios, TH350 trans., high comp. pistons, mild cam, no a/c, heater
Old 08-29-2004, 05:17 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Re: bov question
If you run a blow through unit, the BOV has to be before the MAFS so the MAFS doesn't meter air that will be blown off.
throttle body-----MAFS----BOV-----turbo----air filter
you could just use a SAFCII though.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 09-04-2004, 11:11 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: bov question
depends on what kind of car you have. eclipse, you have a mafs on the airbox, and have to buy a maft and gm mafs to compisate for the air being discharged. what do you have, an eclipse or what it says on your profile?
DSM geek
Old 09-05-2004, 10:00 AM
Re: bov question
i have a '96 Eagle Talon, same thing as an eclipse.
-1996 Eagle Talon
-1972 Malibu
Old 09-05-2004, 11:45 AM
Re: bov question
well, then your question is answerd. buy a MAFT and gm mafs.
DSM geek
