Go Back   Automotive Forums Car Chat > GMC > General Discussion
Old 08-13-2004, 11:15 AM
Ineka Ineka is offline
Parking Brake 2000 GMC Sonoma
Help,
The parking brake pedal on my 2000 Sonoma has gone from very hard to depress but still holding to all the way up, impossible to budge, no brake at all. I have read a bunch of posts with the problem being "pedal all the way to the floor" but nothing on my trouble. I have looked at the cable on the outside of the frame rail, but I don't have a clue what I'm looking for.
Old 08-20-2004, 06:18 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Parking Brake 2000 GMC Sonoma
What may have happened is the brake pedal assembly is in a bind. look under the dash at the pedal assembly to see if there is anything stuck in it (I have seen wiring harnesses sag into the assembly).
If not, check the cable under the truck..give it a tug, if it moves then the cable is free and most likely the pedal assembly is the problem
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 08-20-2004, 09:49 AM
Thank you GMMerlin
I checked for binding and found none. In checking the pedal assembly I did notice that with the brake off, the gizmo (release lever?) that the brake release cable threads through can be pulled slightly forward and then the brake will set. Once I release the brake we are back to square one until I fiddle with it again. If the gizmo is the problem, is it something that can be adjusted or does it have to be replaced?
Ineka
