Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-13-2004, 10:12 AM
peter1 peter1 is offline
Bent Axle?
Vibration starts at 45mph and up, worse when accelerating. Is there away to test for a bent axle other than replace it? Former post FYI I've a 92 camry 4 auto with vibration during acceleration.
Replaced dog bone and front motor mount...cut vib. in half.
Replaced tire (needed then anyway) cut vib. in half again.
But it still has vib. would like to replace rear motor mount.
How, my manual didn't cover it.
I can loosen the motor mount nuts but when I jack the eng. I don't get enough space to remove the old mount?
What am I missing?
Old 08-13-2004, 01:08 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Bent Axle?
Another post about that motor mount?
Old 08-13-2004, 02:30 PM
If its the motor mount yes.
If its the axles no.
Brian, do you know how to test the axles on the car?
Thanks
Peter
Old 08-13-2004, 02:57 PM
Brian R.'s Avatar
Resident Chemist
Re: Bent Axle?
Pull them and check the runout with a dial indicator.
Please don't insert multiple posts on the same problem.
Old 08-13-2004, 03:39 PM
Re: Re: Bent Axle?
Brian , the ? was on axles on the car not off...if you have no help save us all some time!
Old 08-13-2004, 04:14 PM
Brian R.'s Avatar
Resident Chemist
Re: Bent Axle?
I only wasted my time on you. Last time I make that mistake.
