Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 08-13-2004, 04:47 AM
Toke138 Toke138 is offline
Send a message via AIM to Toke138
Motor swap problems
I have a 94 civic ex coupe automatic. I destroyed the d16z6 that was in it and just dropped another d16z6 in. The new d16z6 came of a 5-speed civic.
When I start the car it wont let me put the car in drive and if I put the car in neutral first then start it and try to put it in gear it makes a loud grind noise. Almost sounds like when a starter is engaged on a running motor.
The shift linkage was damaged in the swap but I dont see how it could be related to the grind noise, why would an automatic grind?
I have verified that its not the axles or the torque converter grinding.
Old 08-13-2004, 06:03 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
i hope you didnt put the 5 speed flywheel on with the automatic. did you use the 5 speed IM or did you put on the auto IM on teh 5 speed ? gotta give more info and exactly what you did, what you switched. so we know what you did and didnt do correctly
Team Lonely Drivers
Old 08-13-2004, 09:49 AM
itechengineers itechengineers is offline
Send a message via Skype™ to itechengineers
Re: Motor swap problems
he's got a point there, i would lime to add, why not convert to 5 spd and stay with auto?
Old 08-13-2004, 02:55 PM
I did not use the 5-speed flywheel, if i had then the torque converter wouldnt even bolt to it. Everything between the crank and the tranny was taken from the old motor.
I did not switch it from automatic to 5-speed because I am on a limited budget and I wouldnt have been able to complete the project in 1 day like I did this swap, other than this little problem.
I also prefer an automatic on my daily driver.
