Old 08-13-2004, 12:20 AM
jduerr jduerr is offline
94 s-10 radio wire harness
The jackass who owned this 94 S-10 cut the ends off the radio wire harness to install a Sony aftermarket stereo. The thing doesn't fit at all and the plug will not fit a factory radio (which I'm trying to install).
My question is; where do the wires lead to? I've tried to follow them through the dash and behind the steering column but I cannot seem to locate their origin. I ask this because there is a wire harness at the junk yard in a 94 and I'd like to remove it and put it in my truck. Thanks.
Old 08-13-2004, 02:39 AM
dwinthrup dwinthrup is offline
Re: 94 s-10 radio wire harness
get the junk yard harness and just color code it make sure the colors are right use but connectors to do it i will match you just need to take your time!!!
Old 08-13-2004, 02:40 AM
by the way the wires lead to each speaker front 2 rear 2 and ground
and 2 positive
Old 08-13-2004, 03:28 PM
I got the plastic wire clips that plug into the back of the radio. There appears to be 14 total wires coming from the three clips. Unforunately, I only have 10 or 11 wires coming from behind the dash into the radio compartment.
Old 08-27-2004, 05:20 AM
GMDrew GMDrew is offline
Try this PDF file - it has the pin-outs for the 14-pin harness.
http://www.installdr.com/InstallDocs/GM/PDF/460037.pdf
Drew
