| WIP - Street Post topics for any "Works In Progress" street vehicles projects in this sub-forum. |
scrathbuilding a baja truck
Im starting out with the Revell? Ford F-150. So far, ive sanded down all trim, door handles, attached the rear fenders and lost the truck bed. Then glued hood shot and added front grill. Its only in the putty/primer stages right now. lots of work ahead of me... heres the pic of the truck so far.
![]() ![]() Im gonna turn this ![]() and this ![]() into something along the lines of this ![]() Wish me luck.
Just a good model of mine: 2 Fast 2 Furious SkylineSTOLEN!!! Another go at it: 2 Fast 2 Furious Skyline.. Pt. 2 |
Re: scrathbuilding a baja truck
Good luck!
![]() Current Projects- Ferrari F189 ON HOLD Ferrari 360 Spider Future Projects-04' Corvette Z06, Enzo , F1-2000
looks like u dont need the body, just some styrene sheets and tubing and you'll be fine.
Juat a quick question..does anyone know where the engine goes?
looks like a awesome project!
fore the engine... some teams have the engine behind the seats and others have the engine in front. it is up to you. but i think the one at the pick has it in the front but they have placed it a bit furder back in the car to get 50/50 in weight.
Best Regards Anton |
this should be interesting. This is going to be one where the body comes off like nascar kits? As for the suspension, dump the IFS, and use the solid I-Beam front end off of the AMT 1990's F-150 kits. I'm assuming you're going with a 2wd truck?
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes 1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials 2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater |
heres just a little update. First primer is dry. I Built a new radiator from existing and found an engine and exhaust setup im gonna use. Also, got a little bored and drew up plans for my roll caging and positioning of needed stuff. Still searching for tires.
![]() ![]() More updates as they come
Cool. What kinda engine are you using? Is this going to be a weekend fun truck? Or, are you going to paint it and stick sponsorship decals on it?
RIP Indian Larry RIP
April 28th, 1949 - August 30th 2004 IN GOD WE TRUST VENGEANCE IS MINE SAYETH THE LORD NO FEAR |
Re: Re: scrathbuilding a baja truck
Chevy dominates them all! But a nice 460Cobra Jet ford with two humoungus turbos would work nicely too.
ore a engine from a monster truck. i think it would suit it to.... but then you have a bug catcher to deal with. but those engines have about 1600 hp
you can get those engines out from any monster truck on the market.
use the chevy engine. just glue the
intake on backwards LOL!!! i did that to my camaro and the glue dryed before i seen what i did...
help i've fallen and i cant reach the glue |
youd technically have to use a ford intake. Because on a ford intake the distributor hole and the water hose hole are right next to each other. In the bowties case, the distributor and water hose hole are on other sides of the intake. But, that could work i suppose.
on my moms ford ranger(V6) the dist, is way in back. Its the same with a few other trucks I know. All i did was glue it to the back. Although today i did win a NASCAR model at the contest, so that kit is being parted for this build. Some very nice things that will help me tremendously. I also hve a guy im waiting on for the tires and rims.
I was reading in one of my old model magazines about someone making a rollcage out of brass by soldering them. I had a few peices lying around and tried to solder them with no luck. Has anyone done this?
