Old 08-12-2004, 11:28 PM
greendayhbt26 greendayhbt26 is offline
Send a message via AIM to greendayhbt26
s-10 leaning
my 98 s-10 2.2 manual seems to be leaning i bit on the drivers side. from the back it looks as if it has something heavy on that side and not the other. i was wondering if this was normal or what. could it be cause the gas tank is full since its on that side. if u kno why its doing that and possibly how to fix it, that would be wonderful.
Old 08-13-2004, 01:43 AM
TweakedGM TweakedGM is offline
Re: s-10 leaning
my guess would be the leaf or the shock
Old 08-13-2004, 03:35 AM
dwinthrup dwinthrup is offline
well if you droped the truck it's the chevy lean. if not replace the leaf spring to fix it then you prob is fixed
Old 08-13-2004, 09:28 AM
dugie6551's Avatar
dugie6551 dugie6551 is offline
Re: s-10 leaning
sounds like "THE S10 LEAN".
Originally Posted by lamehonda
AF has ruined my life. .... Thanks AF
Old 08-13-2004, 11:04 AM
Re: s-10 leaning
the shocks are fine, i had them checked. my trucks not dropped so im guessing i gota replace the leafspring...how hard and expensive would that be for me to do myself
Old 08-15-2004, 08:30 AM
tyler62601 tyler62601 is offline
Send a message via AIM to tyler62601
Re: s-10 leaning
they make a spring spacer for s 10 like everyone has said it s the s10 lean. the spacer will fix your lean belltech made one thats where i got mine.
Old 08-15-2004, 10:27 AM
Re: s-10 leaning
isnt the s10 lean on the passenger side..cause mine is leaning on the driver side
Old 08-15-2004, 01:23 PM
Re: s-10 leaning
no. its the drivers side. all you have to do is call someone like belltech or eibach and ask for the spring spacer for an s 10 they ll know what your talking about
Old 08-15-2004, 07:50 PM
Re: s-10 leaning
how much does it cost?
Old 08-16-2004, 07:38 AM
Re: s-10 leaning
did you lower the truck??? i m guessing you did. most times thats the only way you see it. it not very much. maybe 20-30 bucks.i dont remember. it seems the lower you go the more you see it so check that out. if you didnt drop it im not sure whats going on.
Old 08-16-2004, 09:28 PM
Re: s-10 leaning
no i didnt drop it.....im wondering if its the fuel tank cause mine is usually full and the tanks on that side
Old 08-17-2004, 09:34 AM
dugie6551's Avatar
Re: s-10 leaning
The gas tank will NOT cause the truck to have a noticable "lean". You may want to check all the body, bed mounts, suspension (shocks, front coil springs, leaf srpings and all connects for the suspension.)
If you cannot find anything wrong, take it to a autoshop to have a professional look at it. If you haven't lowered it and it has a "noticable" lean, then something is broken.
Old 08-17-2004, 09:45 AM
had the shocks checked when i brought it in for an inspection, they r fine. i checked the mounts..those r fine and it seems that all the leaf springs and other suspension components r fine.
Old 09-23-2004, 09:58 PM
Zarder Zarder is offline
Re: s-10 leaning
I wrote a long answer then lost it when I got disconnected .
Short version; replaced 4 shocks and springs. Now ordered Air Ride helper air springs from trucksprings.com. $190. Should have put in air springs first.P/N ARL59529
Old 09-23-2004, 10:31 PM
movin2stereo's Avatar
movin2stereo movin2stereo is offline
Re: s-10 leaning
I got the same problem.
