Old 08-12-2004, 09:15 PM
jsumi jsumi is offline
'92 Talon - Slight Vibration
My Talon has 214,000 miles and has always run like a top until 2
weeks ago. There is a very slight fast vibration that I notice when
I'm idling or if I rev it high between shifts.
I've had plugs/wires replaced and my mechanic does not see anything
wrong. The car still rides great but this vibration is bothering me.
Its definitely not related to the tires.
I thought it might be a partially blocked catalytic converter but
the mechanic said it looked ok.
Any ideas......? Thanks.
Old 08-12-2004, 09:19 PM
Raz_Kaz Raz_Kaz is offline
Re: '92 Talon - Slight Vibration
Rough enough to rattle your hand when idle at the light...?
Old 08-12-2004, 09:43 PM
Re: Re: '92 Talon - Slight Vibration
I would not say the vibration is rough....but with my hand on the steering wheel it does vibrate......also the driver's side view mirror is vibrating slightly.
Old 08-13-2004, 12:38 PM
MrZ's Avatar
MrZ MrZ is offline
A bit more detail on exactly when the vibration is most apparent would be helpful. However, in both instances described you would have the clutch depressed, right? Maybe the throw out bearing?
Mark
Old 08-13-2004, 12:50 PM
my guess is on the bearings as well. My Talon had similar problems, replaced bearing and things are better now
Old 08-13-2004, 05:39 PM
Re: Re: Re: '92 Talon - Slight Vibration
Here is the best way I can describe it:
The vibration is worse as the RPM's increase and is mostly felt when my foot is on the gas pedal, clutch, or brake. (Not the sterring wheel when I'm driving).
If I'm in 3rd gear at 2000 RPM's it feels smooth, at 3000 RPM's, I can feel it in the gas pedal. At 4000 RPM's, I feel it stronger in the gas pedal.
If I press in the clutch in at those various RPM's, I do not feel the vibration any longer.
Thanks, Joe
Old 08-13-2004, 06:01 PM
mik13usa's Avatar
mik13usa mik13usa is offline
Throw out bearing and pilot shaft bushing need to be checked!
Old 08-14-2004, 07:39 PM
Re: Re: Re: Re: '92 Talon - Slight Vibration
Thanks for the tips. Someone on the yahoo board mentioned Timing belt could be a problem....I have not changed my timing belt for 100,000 miles....
Thanks, Joe
Old 08-14-2004, 11:38 PM
96TSi's Avatar
96TSi 96TSi is offline
Send a message via AIM to 96TSi
dead cylinder or timing belt id say. but it is a DSM so it could be a washer on your windshield wiper motor thats making it do that
04 SRT-4
03 Evo
96 Talon TSi AWD *dead*
93 Talon TSi AWD *sold*
85 300ZX Turbo
90 300zx Twin Turbo
82 Karen
04 little boy
Old 08-15-2004, 01:17 PM
MrZ's Avatar
MrZ MrZ is offline
jsumi;
Definitely change the timing belt if you have that many miles on it! Can't say for sure that it's the source of the vibration, but it very well could be.
In case you didn't know, DSM's have zero valve clearance. If that belt breaks or jumps time while you're driving you could be looking at some serious internal engine damage. Don't wait, it isn't worth the risk.
Mark
Old 08-15-2004, 08:41 PM
OK, thanks everyone. I'm away but will have it checked out next week.
Joe
Originally Posted by MrZ
jsumi;
Mark
Old 03-24-2005, 12:00 AM
dmc67 dmc67 is offline
Send a message via AIM to dmc67 Send a message via MSN to dmc67 Send a message via Yahoo to dmc67
Hey I had something similiar too this and tour my tranny outta car and the shaft the Throw Out bearing rides on broke off flush with the tranny.
