Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 08-12-2004, 08:34 PM
sbh1602 sbh1602 is offline
Where can I find...
The starting motor on my Cutlass Ciera '93?
Old 02-27-2005, 02:15 PM
gjkalata gjkalata is offline
Re: Where can I find...
I am unsure as to if you have recieved any replies to your inquiry, but I had to replace my starter on my 91 Olds Cutlass Ciera. You can find the starter motor in the front under the front exhaust pipe, and of course, right above the frame bracket. You need to disconnect the battery as the wires attached to the starter will come in contact with the bracket as you remove it. There are 2 bolts attaching the starter to the motor and the one in the back is almost right above the frame making it difficult but able to remove it, then you have to slide the starter out in front of the frame and disconnect the wires to be able to remove. To install a new one, just reverse the steps but I will warn you that the rear bolt is a real pain to get restarted. Good luck.
