Old 08-12-2004, 09:26 PM
berkes454 berkes454 is offline
help!!!!! need more power!!!!
ok i just pulled the specs on the motor going in my Camaro
its out if a 82 caprice classic heres the specs
90-Degree, Overhead Valve V-8
Cast Iron Block and Head
Engine VIN Code - H
Engine No. Cyl. Displacement: 305 Cu. In.
Liter - 5.0
Engine Mfg. - Chevrolet
Carburetor Type - 4Bbl
Horsepower @ rpm - 145@4000 ---
Torque @ rpm (ft. lbs.)- 240@2000---
Bore x Stroke (in.) - 3.74 x 3.48
Compression Ratio - 8.6:1
Oil Pressure @ 2000 rpm - 45
Five Main Bearings
Hydraulic Valve Lifters
i have the money for some good bolt ons but i need alot of suggestions......id like to have at least 250-350 horses
HELP HELP HELP HELP HELP HELP
people = $#!T
Old 08-12-2004, 09:42 PM
camaromaniac camaromaniac is offline
Re: help!!!!! need more power!!!!
dude just get a 350 engine. thats about 300 hp right there
Old 08-12-2004, 09:45 PM
part of deal with my parents for getting the car back was i had to use the 305............damn them
people = $#!T
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
You should'v used a 350 block instead..
But here are some suggestions!
CompCams enRGy cam, edelbrock intake mani, new carb, Aftermarket heads, (or get yours r&r'd and ported/polished) flat top pistons, Edelbrock TES headers, MSD ignition system (distributor, coil, wires, 6AL..) underdrive pulleys, electric waterpump.. etc etc etc
1991 Camaro Z28
Old 08-12-2004, 09:47 PM
DaMoNe6969's Avatar
and make sure the bottem end can handle the mods
1991 Camaro Z28
Old 08-15-2004, 05:34 PM
how much can i gain on torque and horsepower when i pull off all the emmisions???? and when i do a tune up??..........the car has been sitting for 4 years.........threw a battery in it and it fired right up.......its got about 80,000 miles.
people = $#!T
Old 08-16-2004, 09:44 AM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
the 305 is the same block as the 350. all you have to do is get a 350 crank and pistons and you will have a 350 (whilest the parents think ye have a 305). also, 300 out of a 305 is more than do-able, depending on how much you are willing to do and spend. 92RS is the king of kings when it comes to 305 performance. he hasnt been on in a while but try PMing him to see if he responds...
*Better power-to-weight ratio than a C6 corvette*
Old 08-17-2004, 06:33 PM
thanks guys
people = $#!T
Old 08-17-2004, 06:34 PM
i cant find 92rs on the members page did he get banned??? or somthin??
people = $#!T
Old 08-17-2004, 06:40 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
http://www.automotiveforums.com/vbul...r.php?u=117863
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 08-17-2004, 07:03 PM
DaMoNe6969's Avatar
his nick is 1992RS
havent seen him around in a while
1991 Camaro Z28
Old 08-17-2004, 07:08 PM
Dober89 Dober89 is offline
Re: Re: help!!!!! need more power!!!!
Wut u talkin bout willis?? The 305 and the 350 have the same stroke but the 305 has a smaller bore. You CANT bore a 305 out to 350. The only thing you can do to the 305 is bore and stroke it a bit and get it to around 335 I think.
You can get some decent power out of them but you will definately find that 350 parts are cheaper and more plentiful.
Old 08-17-2004, 07:37 PM
willis lmao
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
Old 08-17-2004, 11:00 PM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
Re: Re: Re: help!!!!! need more power!!!!
that's not true, they are both small blocks. you could bore and stroke it all the way to 400 if you wanted. i'm not sure if the stroke on a 305 is the same or not, but i do know that w/ any small block you can bore and stroke it to at least 400, so getting his to 350 would be do-able
btw the ls1 small block can be bored and stroked all the way to 427, that's a big ass small block!!!
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 08-17-2004, 11:25 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: Re: Re: Re: help!!!!! need more power!!!!
wrong yourself there my friend, the cylinder walls of the 305 are too close to the water jackets to bore it out any further than the 335.
