Old 08-12-2004, 06:53 PM
jah_shed jah_shed is offline
Send a message via Yahoo to jah_shed
Question door hinge replacement
I need to replace the driver side door hinges on my 1997 Blazer and for the life of me cannot figure out how to take the old ones out. can anyone help me???????
Old 08-13-2004, 12:39 AM
ajk114 ajk114 is offline
The hinges themselves are welded to the door and body. Normally the hinge pin and bushings are the parts that wear out and are easily replaced. The bushings, pin, and retainer run $8.00 from the dealer (each hinge) and you will need a door spring compressing tool to get the spring in and out. Got mine from handsontools.com ($16.00) part no.SGT87690. Repair one hinge at a time, wrap a couple of layers of duct tape around the leading edge of the door and the trailing edge of the fender to protect the paint. Remove the spring, remove the pin retainer, use a hammer and drift to knock out the pin, replace the bushings, pin and retainer. Its a 30 minute job. Keep everything well lubed or you will end up replacing these annually.
Good luck,
Old 08-13-2004, 04:23 AM
98blkblazer 98blkblazer is offline
Cool Thanks AJ
I need to do the same on my 98.
