Old 08-12-2004, 04:06 PM
chevycanadian chevycanadian is offline
Question mod ideas for my 03 silverado Ext 4x4
just any one that has any ideas for some performance mods for my truck would be a great help,i just got it and im looking for ideas. Thanks
Old 08-12-2004, 07:48 PM
vnotaro vnotaro is offline
Do a search on this forum for "mods" or anything else you can think of. I promise you won't have enough time to read them all!
Old 08-13-2004, 02:46 PM
SocalSilverado SocalSilverado is offline
simple cheap mods
AEM Cold Air Intake
40 or 50 Series Flowmaster
Old 08-14-2004, 09:52 PM
02blackstallion 02blackstallion is offline
Send a message via Yahoo to 02blackstallion
Re: mod ideas for my 03 silverado Ext 4x4
Performance? Supercharger, Procharger says 60-65% increase, thats like 160 hp!
Black 2002 Silverado Ext Cab, Stepside, Z71, LS, 5.3
Quick Time Performance Electric Exhaust Cutout
Hypertech Power Programmer III
Granatelli MAF Sensor
Kills
5spd Mustang
5spd Civic
Old 09-04-2004, 01:39 PM
brian_fthood brian_fthood is offline
I would avoid a vortech blower... I had one and got burned by the warranty folks when the impeller shattered and took out my whole engine. So, think buying and installing a blower, then buying and installing a new engine.... it wasn't cheap. I recently got to work with a couple of guys from procharger on a TV show. One of them was one of the original designers for Vortech and now works for Procharger if that tells you anything. I am currently looking into putting a procharger system on my new engine.
When researching blowers, make sure you check out the companies tech support system. Modern engines have a lot of computer managed systems, fuel, torque management, etc. Most kits come with a fuel control unit and a VIN specific tuner to fix some of this stuff. Make sure they will fix your torque management or all that new power is gonna get checked by your computer to keep the tires from breaking loose! (speaking from experience) Also, if you have a 5.3 like mine (i'd assume the same for the 4.6) you need to get a kit that has an intercooler. Otherwise, your air mass will get too hot for your engine which runs around a 9:1 compression ratio. Kits without intercoolers have tuners that retard your timing to adjust for this which gives you nowhere near the power gain an intercooled system will give you. This is the kind of stuff they won't tell you unless you ask.
Will post more info on the procharger kit as I research and hopefully install...
BJ
