Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 02-04-2002, 01:07 PM
khead717 khead717 is offline
Adjusting Coilover
Hi, anybody know if there is a way to adjust the coilovers with out taking the wheels off? because it's too much hassle to remove the wheels everytime i adjuest the height.
and also, where do you guys measure the height to get the right height that you want? sometimes i lower it too much,...sometimes not low enough....
thanks for your help
Old 02-04-2002, 03:02 PM
94civic's Avatar
94civic 94civic is offline
i don't think there is a way to adjust the coilovers without removing the tires, unless you have airbags
Old 02-04-2002, 11:17 PM
So where do i measure to lower the right height that i want?
let's say i want to have the tires even with the fender, do i measure the gap between them, and lower the same amount when adjusting the coilover?
Old 02-04-2002, 11:39 PM
Someguy Someguy is offline
Send a message via AIM to Someguy
The best place is a suspension mounting point, such as the front lower control arm chassis side mount, and then when on a set of 4 wheel corner scales with you in the driver's seat. But I take it performance isn't the primary goal here?
Old 02-04-2002, 11:44 PM
hybridDC2 hybridDC2 is offline
only way you'll be able to adjust them if you can fit your hand through your rim. like in my case with my 17'' 8 spokes, i dont ever need to take my wheels off. get some 22" 3 spoke rims for the ultimate in ease of adjustment :silly2:
Old 02-04-2002, 11:51 PM
i am sorry....i am dumb...i don't understand a word what u are saying....
Old 02-05-2002, 02:58 AM
justanothermike's Avatar
justanothermike justanothermike is offline
Send a message via AIM to justanothermike Send a message via Yahoo to justanothermike
u can jack up the car so the wheel is off the ground, then reach around the wheel or turn the wheelt to one side and then adjust it. It should be much easier this way instead of doing it with the car on the floor. and the best way measure for height is to measure from the center of the wheel to the lip of the fender.
Old 02-05-2002, 01:45 PM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
Yep I jacked my car up and reached around the wheels - and on my other wheels through them to adjust them without taking the wheels off.
Also I would write down how far the collar would be from the seat of the shock if I wanted to slam my car then put it back up for driving home.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 02-06-2002, 04:46 PM
FLAWLESS FLAWLESS is offline
Send a message via AIM to FLAWLESS
All you need to do is jack it up to adjust the coilovers, there's no need to remove the wheels, you can reach around.
The most accurate way to measure ride height is from the ground to the bottom of the fenderwell. Remember that the left side of the car is heavier, so the adjustment on the actual coilover will be different from left to right.
Lowering the front more than the rear will promote oversteer.
Lowering the rear more than the front will promote understeer.
Experiment with different settings to get the best results. It takes time.
98 Civic LX - Bottle-Fed
Anyone installed Tokico Adjustable Coilovers? SleeperTeg Tires and Wheels 6 05-15-2002 12:57 AM
adjustable coilovers...90 civic hatchback outofstep '71-'87 Civic | CRX 1 04-05-2002 07:59 AM
adjustable coilovers...90 civic hatchback outofstep '71-'87 Civic | CRX 0 04-04-2002 08:05 PM
adjustable coilovers...90 civic hatchback outofstep '71-'87 Civic | CRX 1 04-04-2002 07:38 PM
Air Bags or Adjustable Coilovers? buh_buh Tires and Wheels 10 02-03-2002 02:42 PM
