Old 08-12-2004, 10:54 AM
41plympktrk 41plympktrk is offline
Send a message via AIM to 41plympktrk
Header help
Will long tube headers work on a s10 v8 conversion? Is there any way to make them work? I'm just using the s10 frame and putting a whole other body over it.
thanks for any help,
Jeff
Old 08-12-2004, 01:33 PM
dugie6551's Avatar
dugie6551 dugie6551 is offline
Re: Header help
No, regular headers will not work. The issue is the distance from the engine block to the inside edge of the frame. It is just too tight to fit normal headers in that space. On top of that there is no space left when the starter is put on and the steering shaft/linkage in the way; regardless of what body you put on. They do make aftermarket headers for a V8 S10 conversion that works around the tight spaces. You might want to check out www.jaguarsthatrun.com for any info.
Originally Posted by lamehonda
AF has ruined my life. .... Thanks AF
