Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 08-12-2004, 09:33 AM
FR1993 FR1993 is offline
Hard to shift into first gear
Recently I have noticed that it is sometimes very difficult to shift to first gear when I start my truck. It only happens sometimes... other times it is just fine.
My boyfriend drove my truck the other day and first gear gave him a hard time too... now, he said I will probably have to replace the clutch... but I have been researching some similar topics on here and I don't think I have to go as far as changing the clutch...???
From what I have read, it may be the hydrolic (sp?) fluid...? ANY help would be appreciated... because God knows I'd rather replace some fluid than have to put a whole new clutch in.
Thanks.
Old 08-12-2004, 10:27 AM
ModMech's Avatar
ModMech ModMech is offline
Re: Hard to shift into first gear
If you ONLY have troubles shifting into 1st while stopped (you can get into any other gear ok), then it's not the clutch but the transmission.
Old 08-12-2004, 02:10 PM
Re: Re: Hard to shift into first gear
Well it actually does it sometimes when I go to put it in reverse... please say it's not the transmission....??
Old 08-15-2004, 01:05 AM
trannyman52 trannyman52 is offline
if the slave cylinder on the firewall is full,,,if the clutch pedal has full
travel,,,,the clutch is probably shot!!!!
Old 08-16-2004, 04:54 PM
freeclimber freeclimber is offline
Oftentimes a bad pilot bearing will make shifting into gear difficult. It locks the flywheel onto the inpuft shaft of the trans and doesn't care if you're pushing the clutch in or not. These bearings can go well before the clutch is worn out, especially if you idle the truck a lot.
A worn clutch will slip under load, it won't make shifting harder. Check your resevoir for fluid first. The slave cyl could be leaking.
