Old 08-12-2004, 07:57 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Talking My first Log!!!!
I received my pocketlogger program and cable yesterday and created the following logs. I would like to know what you guys think. Here is my mod list : T25 @15psi, 1g BOV, JoeP MBC, Injen Intake, Extreme Downpipe w/Hi-Flow Cat, Brode UICP, Magnecore Wires (I doubt this changes anything). I am considering geting a SAFC-II but I'm not sure if it is worth it?? Should I save my money for something else?? Just remember that I'm the guy that doesn't want to upgrade the catback. Thanks.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 08-12-2004, 04:29 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: My first Log!!!!
I don't think the S-AFC will benefit you that much, even if you knew how to tune it very well on a T25. If you plan on getting a bigger turbo, buy the S-AFC then.
For the logs, I'm not one of our members that can read these to the tee, but were you misfiring any, especially right when you stepped on it?
Old 08-12-2004, 08:55 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
is their a log for the degree of knock?
DSM geek
Old 08-12-2004, 09:37 PM
JoeWagon's Avatar
Banned
2g's don't have knock sensors, remember? DSMlink can do it... pocketlogger cannot. I don't remember if I heard Kevin say that 1 count of knock is 1 degree of timing retard, or if I just made that up. If not, it's directly related anyway.
Old 08-13-2004, 07:18 AM
Re: Re: My first Log!!!!
Not that I noticed. What would make you ask that???
1997 Spyder GS-T
5-Speed
Old 08-13-2004, 01:00 PM
JoeWagon's Avatar
Banned
the timing goes down before you get to full boost
Old 08-17-2004, 01:10 PM
I thought that was normal? As long as timing continues to increase throughout the gear?
Below is another run, I lowered the number of parameters trying to get more samples per second. I also logged O2 voltage as some suggested. I notice that my O2 voltage, for the most part, is between .90 & .92. Isn't this considered lean? Also I noticed that the timing is being pulled in the upper rpm range in 3rd gear. If I remember correctly GSXRacer has said this is because the ECU has heard knock. Should I get the AFC and try to add fuel to bring the O2 voltage up and reduce knock in the upper rpm 3rd gear range. Or would the AFC be useless?? Thanks!
1997 Spyder GS-T
5-Speed
Old 08-17-2004, 01:13 PM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
A real good indicator of what tuning would need to be done has to include more RPM points.
Put it in 2nd (or third) and cruise about 2500rpm, then get into the throttle and log to the 6k+ range.
No need for multiple gears, really. You want a gear that sees a good bit of load, hence nobody logging in 1st.
Kris
2012 Genesis Coupe 2.0t
Old 08-18-2004, 08:51 AM
I have the log from 2500 to about 7300 rpm's. I will hotsync later and post it. But another question while I have time here at work to do nothing . I read one of Kevin's posts saying that when the ECU sees intake temps above 85 degrees that it will retard the time by one or more degrees. I was cruising around yesterday and my intake temps were fluctuating between 89 & 91 degrees. I was on the expressway doing about 70 during that time. Is this normal?? Also Kevin had indicated that at coolant temps above 206 degrees you loose another degree of timing. Mine were fluctuating between 203 & 206 is this normal?? I will post the log later.
1997 Spyder GS-T
5-Speed
Old 08-18-2004, 06:30 PM
JoeWagon's Avatar
Banned
what was the ambient air temp? nobody can say if it's normal or not, because at 100 degree california weather, you might never get under 85 degrees on a stock SMIC. Most likely IS normal because you aren't running too radical of a setup. Probably not too high boost on a stock turbo which might cause it, and stock SMIC can't be helped.
I think coolant temp should stay below the ECU warning level though, maybe try some water wetter in there to get the heat out better.
Old 08-19-2004, 07:20 AM
Here is the 3rd gear pull that Lando suggested. Is the "water wetter" available at places such as Autozone? By the way, it was about 75 outside.
I see that my timing is getting pulled all over the place. What do you guys think? Should I go ahead and order the S-AFC II??? I also see that my o2 voltage seems to be dropping (leaning out?). Is this a fuel delivery problem or is the ECU not taking care of the adjustments. Any help would be appreciated. I am basically just looking for weather or not it is worth it for me to get the AFC? If I do get it I will definitely have tuning questions later
1997 Spyder GS-T
5-Speed
Old 08-20-2004, 08:43 AM
Can anyone help me??
1997 Spyder GS-T
5-Speed
Old 08-20-2004, 08:48 AM
5392 and 6892 are the only timing pulls. Other than that, it seems like you have a good thing going.
Kris
Old 08-20-2004, 10:01 AM
So when I get my S-AFC II I should add a little fuel in those areas? What about the O2 voltage, isn't that a little lean. Or doesn't it matter because I'm not getting the timing pulled?
1997 Spyder GS-T
5-Speed
Old 08-20-2004, 11:36 AM
O2 volatge is useless, and the areas where timing IS being pulled would be difficult to pinpoint, even with 12 NE points. (is that how many the SAFCII has??)
Kris
