| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
Rear end noise
I recently replaced the rear end of my 68 Camaro with a 12 bolt posi.
The problem is when I drive the car I can hear a clunking noise coming from the rear end. What could be causing this??? |
Re: Rear end noise
Were you certain to put the "posi additive" in there? The clutches in the posi will make clunking sounds when the lube isn't used. You can get the good stuff from any GM dealer.
Re: Rear end noise
I did put the additive in just one tube maybe two would work better.
Re: Rear end noise
U-Joint maybe? At what speeds? Normally only one bottle of 1052358 GM LSD additive is enough for the rear end.
Re: Rear end noise
It makes the noise at low speed I haven't driven it
above 5 MPH. The additive I used was brandx off the shelf. I didn't think that would make a difference. |
Re: Rear end noise
Radarman, we've seen hit-and-miss success with the aftermarket products. The GM is a known quantity. Does it make the same noise in reverse? Or is it possibly more pronounced in reverse? If so, the posi is certainly the culprit. Check your u-joints closely, too, as previously suggested.
just pack it with sawdust! That will fix it!
Re: Rear end noise
Is your pinion angle correct? Did you build it yourself? Rear ends are difficult to get 'just right' if you are inexperienced with them. Check the u-joints for bad needle bearings and make sure to lubricate them. (I've been known to install u-joints and forget to grease them)
1977 GMC Jimmy - daily driver-sitting on 33's and bedliner inside and out 1995 9C1 Caprice - winter beater 1994 Impala SS - newest project 1991 9C1 Caprice - (rip) "There are two great problems in the world today; an ever-growing lack of common sense, and too many warning labels. Take away all of the warning labels and the problem will work itself out..." -B |
Re: Rear end noise
I didn't rebuild it but I will check the u-joints.
I drove the car yesterday and it did seem to quiet down but now it makes noise wen I take a sharp turn. |
