Old 08-11-2004, 11:18 PM
Nayr747's Avatar
Nayr747 Nayr747 is offline
Radiator Drain Location -PLz Help
I am flushing my coolant system but I cant find the drain on the radiator. Can someone please help. And what should I use to get it off? My car is a 98 GP SE 3.1. Thanks!
Old 08-11-2004, 11:37 PM
Nayr747's Avatar
Re: Radiator Drain Location -PLz Help
The manual says there are 2 air bleed valves, one on the thermostat housing and one on the thermostat bypass tube. Are these what im looking for? Where is the second one? I cant find it. I looked all over the bottom of the radiator and couldnt find anything.
Old 08-12-2004, 10:42 PM
93_R/T_TT_Stealth's Avatar
93_R/T_TT_Stealth 93_R/T_TT_Stealth is offline
Send a message via AIM to 93_R/T_TT_Stealth Send a message via MSN to 93_R/T_TT_Stealth Send a message via Yahoo to 93_R/T_TT_Stealth
its on the passenger side on the bottom - but kinda on the side the faces the engine so its probably visiable from the top of if ur under look at it where the front passenger side tire is an look forward to where i explained - Good Luck!
Old 08-23-2004, 02:31 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
according to the gm parts locator, the drain is on the drivers side, bottom of the tank and should be able to be removed with your fingers or if it's stuckl , a pair of pliers
