Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-11-2004, 11:13 PM
animal401 animal401 is offline
Clutch and such!
After having the head gasket and other work done, I am now having problems wiht the clutch. One day it just started and came to the point that I would not drive it anymore and towed it to a friend. He thought it was just the 'master' cylinder or the 'slave' cylinder (not sure if I am using the rihgt terms). He fixed the master cylinder and that wasn't the problem, so now he thinks I need a new clutch. So I am wondering wouldn't I have noticed if the clutch was starting to fail? Not just notice it one day out of the blue! I think the last clutch that went on me was my 89' civic and it progressed from not good to bad over a longer period of time. Any help would be great. Thanks.
Old 08-12-2004, 12:49 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Clutch and such!
Clutches can die in a minute.
If the car is in gear and the engine can't put power to the wheels, it's the clutch.
Old 08-12-2004, 10:18 AM
I think that the car will drive right now the problem I believe is in changing the gears. It started with shifting, I couldn't shift into gear. If the car was on gear it would go. Any other possible reason that it could be? Thanks for the response and the help/advice.
Old 08-12-2004, 10:30 AM
Brian R.'s Avatar
Resident Chemist
Then the clutch is good and just not releasing. Probably your clutch line needs bleeding, like a brake line.
