no power to ignition module
93 buick lesabre not getting spark. computer, ignition module , coil packs and fuses check out ok. checked the pink wire going into the ignition module for power-none present. used a paper clip and some wire to make a jumper from battery to the module(pink wire). car started right up, thought i was gettinng closer to my problem. tried tracing pink wire-didn't get too far, think it went to the fire wall? tried the jumper trick again-this time, for some reason it didn't start. back to square one, with no spark or power from pink wire, and jumper doesn't work. need some help with this before i break down and bring it to my mechanic. any suggestions would be greatly appreciated!
