Go Back   Automotive Forums Car Chat > Ford > Contour
Old 08-11-2004, 07:10 PM
kayross27 kayross27 is offline
speaker cover
My front passenger side speaker is acting like its blown, sometimes.. like its only doin it ever now and then so i was going to go look at it but i couldnt figure out how to get the cover off.. anyone know?
Old 08-12-2004, 01:30 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
The whole door panel actually has to come off. Youll have to remove the screw cap located on the defrost vent, inside the door handle, and the actual door handle insert. I find a razor blade works best for popping out the screw caps. Besides the screw behind the defrost vent and inside the door handle theres also 2 screws located on the side of the door where the cloth/leather wraps around the door panel, 2 underneath the door panel, 2 inside the door panel, and 2 inside the door handle insert. After all these are taken out, pull the door panel up and it should slide right out. Oh yeah, one more thing...youll have to disconnect the window switch and slide the door handle through the upholstery.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
