Old 08-11-2004, 06:32 PM
family6160 family6160 is offline
2000 Caravan Code
I have a 2000 Dodge Caravan, V6 3.3L, Auto, Air.....
The check engine light is on, so I took it to autozone.
The code they were able to pull was "P1698" & The only info they were able to give me was "Aux Input" and "Aux Output." They told me to contact the dealer for more info, and the dealer said that code is useless to them, and they'd have to do their own diagnosis ($90, plus the labor charges based on time).
I am hoping someone will be able to help me out with this.
Some symptoms of the car: A high pitched hiss/squeal when accelerating. The Coil & Spark Plugs are brand new.
Someone suggested that maybe its the emission control module or something like that, but they're not sure.
Any Ideas?
Thanks in advance!!!!
Old 08-13-2004, 11:37 AM
Big Papa Big Papa is offline
Re: 2000 Caravan Code
I found a list of codes and a description of your code at the following URL
http://www.allpar.com/fix/codes.html
1698 No messages received from the electronic transmission control module or the Aisin transmission controller.
Regards,
Big Papa
Old 12-28-2005, 03:54 PM
rrmr4321 rrmr4321 is offline
so what happened finally. I also got same code for same vehicle now. Please reply.
Old 12-28-2005, 05:28 PM
RahX RahX is offline
there isnt any communication from the transmission control module.
Old 12-28-2005, 06:44 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
As always check the fuses and power supplies first.
This link has the repair flow chart for the code 1698.
http://members.troublecodes.net/crunch/1698.pdf
Good luck
MT
MT
Old 12-30-2005, 09:49 PM
Re: Re: 2000 Caravan Code
You need to do the reply on the original person who posted. I just gave what limited information that I had found. Hopefully that person will reply to you.
Regards,
Big Papa
Old 12-31-2005, 09:12 AM
I believe it ended up being that the main engine wire harness was damaged in an accident prior to us buying the car, so the connection was loose...
We Replaced the wireharness, and almost all the problems went away, except the annoying noise is still there, and nobody can figure out exactly where it's coming from, since it only comes from under the hood when the car is moving + accelerating...
