Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 08-11-2004, 06:12 PM
kerryTrooper kerryTrooper is offline
92 Trooper (check tranny light)
My "check tranny" light comes, almost every time I drive it, and when it does the tranny is switched to the winter mode, in that I only have third gear. I, simply, stop the engine then restart and everything is normal again. The fluid is topped off, but does need to be replaced. Does it just need a fluid replacement or something more? Thanks for any information you have.
Old 10-28-2004, 02:53 PM
StateTrooper StateTrooper is offline
Re: 92 Trooper (check tranny light)
I have same trouble. Did you get any replies?
Old 10-28-2004, 05:38 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
if it is automaticaly going into winter mode on its own you may try pulling the swithch out and cleaning it I have seen spilled coke or coffee cause this to happen
Old 10-28-2004, 05:58 PM
I don't think it's the switch
I don't believe it is actually going in to the winter mode. The winter mode light does not come on, and I know this light functions when I press the winter mode button. The tranny does, however, go in to 3rd gear and the check tranny light flashes. It seems to be some kind of safely feature and I believe that a sensor is causing the problem.
Old 10-28-2004, 08:21 PM
good chance that it is either the force motor solenoid or another shift solenoid that Isuzu referrs to as shift solenoid B
Old 10-29-2004, 06:35 PM
I have replaced my w/mode switch. I'm still having same problem. Where are the solenoids located? My Trooper is also a '92.
Old 12-16-2004, 12:05 PM
dirthawker dirthawker is offline
same thing happend to me. turned out to be my alternator. it was going bad and wasnt giving the ecu enough amps.
Old 01-03-2005, 07:05 PM
Did you ever get the problem fixed? I did. I cleaned the terminals at the connectors under the console where the winter mode switch plugs into the harness. Haven't had a problem since.
