Old 08-11-2004, 04:13 PM
96CamaroSS's Avatar
96CamaroSS 96CamaroSS is offline
98 Camaro SS dome light problems
We've got a 98 SS convertible that the dome lights don't come. Even if you over-ride them with the dimmer switch they don't come on... I have checked the fuses, and all the bulbs. Although if you turn the map light buttons on the mirror on those lights will work. When I took the side panel lights out and used a test light on them both wires coming to the light show they have power. (blue and white) I was wondering if anybody has had a similar problem or can help me out.
Thanks
Old 08-12-2004, 10:34 PM
96CamaroSS's Avatar
Re: 98 Camaro SS dome light problems
Does anyone know what would cause this?
Old 08-12-2004, 10:51 PM
DiabloGT's Avatar
DiabloGT DiabloGT is offline
Banned
cmon guys help him, i cant really help cause it didnt happen to my 99' so ill try to ask my uncles tomorrow and see if they can help
Old 08-13-2004, 02:39 AM
boots03 boots03 is offline
Send a message via AIM to boots03 Send a message via Yahoo to boots03
Convertibles have dome lights?
Old 08-13-2004, 02:50 AM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
good call... what lights are you talking about?
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 08-13-2004, 02:53 AM
DiabloGT's Avatar
Banned
Re: Re: 98 Camaro SS dome light problems
im confused on that too lol
Old 08-13-2004, 02:56 AM
twdz28 twdz28 is offline
he is talking about the ones on the rear view mirror im sure??? come on guys use your heads, thats the only way they came...
Have you removed the dimmer switch and checked ohms or just check power at that point??? im thinking its gotta be around that area...
Old 08-13-2004, 11:48 AM
96CamaroSS's Avatar
The lights that are not working are the ones on the mirror and the back side panels below the rear speakers (that's were they are on convertible). What's weird is that both wires going to the light bulb both are hot with 12v. I thought that the dome lights worked with a ground system like the older cars. When the door was open it closed the ground circuit and turned on the lights. But both leads going to the light are hot.
Old 08-13-2004, 11:52 AM
Maybe the door switch is sticking. Does it tell you if the door is open when it's in gear?
Old 08-13-2004, 11:56 AM
96CamaroSS's Avatar
98 and up Camaros the switches are built into the door stricker... Lights don't come on if you open either door or if you turn the dimmer switch. I don't have a clue why both leads coming to the light have power.
Old 08-13-2004, 12:01 PM
do you have a alarm or keyless entry??? is so the problem may be there...
Old 08-15-2004, 11:59 AM
cbrads1966 cbrads1966 is offline
I'm experiencing the same problem with my 99 convertible. I've tried programming the lights several different ways and to no avail.
Old 09-26-2004, 09:53 PM
dcronshaw dcronshaw is offline
I just bought a used 98 Camaro Conv. V6 for my daughter. It has the same problem, no interior lights come on when you open a door. It has the security system but is programmed for "Exit Lighting" & "Delayed Illumination" which is the default (Mode 4). I have 12 volts coming to both leads of the light which is located in the rear, side panel, by the speaker. I also hooked the light directly to the battery and it worked fine. The other side is the same. I assume when you open one of the doors, the door pin is suppose to ground one side of the circuit. I took both door pins out and tested their continuity and they are working fine. I was wondering if there is a controller that has gone bad, maybe the chime box located behind the glove box?? It has a lot of wires running to it. My map lights work only with the switches on the mirror. The owners manual says the map lights are suppose to come on when you open the door. The interior lights do not come on when you rotate the dimmer wheel all the way up also. When you open either door, there is no chime nor no lights. This sounds like a problem common in convertibles. The chime does work if the headlights are left on and the door is opened.
Old 10-04-2004, 10:24 PM
I think my problem is a bad BCM (behind the glove box). I left all 3 of the harnesses unplugged from the BCM. At the Black harness, I jumpered the Orange (battery 12 volts) wire with the Blue/White (courtesy light) with a 20 amp fuse in-between (same as the courtesy fuse). In the large light blue harness, I jumpered the White wire (D1) to ground. Sweet! The courtesy lights came on! I then jumpered the White wire (D1) with the Grey/Black (D11 driver door pin) and the lights came on when I opened the driver door. Ditto for the passenger door pin (Black/White D12) and dimmer (grey C7) wire. I plugged the 3 harnesses into the BCM and the lights did not work again. Now that I know I did not have a short, I jumpered the wires as described above in the light blue harness, but this time with all of the harnesses pluged into the BCM and the courtesy lights worked. So I'm 99% sure the BCM is bad. How much you ask? Around $200. I think my extended warranty I bought from the dealer will cover it. It lists electronic control module as a covered component.
Old 10-05-2004, 01:45 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
has anybody tried testing the door switches??
*Better power-to-weight ratio than a C6 corvette*
