Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 08-11-2004, 11:57 AM
Crystal3477 Crystal3477 is offline
Send a message via Yahoo to Crystal3477
96 rodeo electrical problems
Can anybody help me out with my electricl problems, I was trying to install a cd player and it blew some fuses, I replaced the fuses but now I don not have any panel lights and all my other instrumental lights in the car doesnt work either and my factory stereo will not work unless I turn on my headlights first. I was wanting to know if possibly I shorted something out or if its a bad relay. Please help..its driving me mad. Thanks
Old 08-11-2004, 01:09 PM
desmarkus desmarkus is offline
Re: 96 rodeo electrical problems
Did you put the factory stereo back in?, or was it left in and you were putting another deck in along with it?
hard to diagnose electrical problems without being there to look at it. start by checking if the deck has constant power, moreover, is the correct power wire connected to the stereos constant power. then start checking each wire to see if it is correct
check here for wire colours http://www.autotoys.com/New_Tech/Wir...ire_colors.htm
unless the harness has been tampered with before. in which case the job becomes more tedious
as for panel lights: same type of trouble shooting inspect wires and bulbs and check relays. make sure the fuses don't keep blowing on you after they are changed.
good luck... I hate electrical problems
2002 Chevrolet Venture, 3.4L 6Cyl. 4 door (4 speed automatic)
1997 Dodge Caravan, 3.0L 6Cyl. 4 door (3 speed automatic)
- Des Markus
Old 08-11-2004, 08:36 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
egg on sidewalk on hot summer day (its cooked)
Old 08-11-2004, 08:38 PM
you may want to check all fuses dont just look at them test them make sure they are good and not only the ones inside the vehicle but out in the PDC also
Old 08-13-2004, 08:17 AM
Yes, I did put the factory stero back in. Thanks for the info and the wire colors, I will be sure and do that. I hate electrical problems too, I am doing good just learning the vehicle componenets itself, much less to get into detail with the wiring system
Old 08-13-2004, 09:39 AM
I'm still working on getting High speed at the new house. (smaller community, and for some reason it takes a month to get a DSL hook up ) As soon as I do I'll try to scan the wiring diagrams you need and post them.
I let you know when I do.
- Des Markus
Old 08-17-2004, 10:31 AM
thanks, desmarkus
Old 08-17-2004, 11:23 PM
I posted it temporarily on my website,
http://www.geocities.com/desmarkus/96_WIRING.jpg
or if that doesn't work try
http://www.geocities.com/desmarkus/Sprint.htm
and if you need a different one let me know
- Des Markus
Old 08-19-2004, 01:06 PM
If or when you get the diagram off my site let me know so I can take it out of there. It kinda sticks out like a sore thumb
Hope it helps!
- Des Markus
Old 08-28-2004, 12:15 PM
I'm taking the schematic of my web page, if you didn't get it e-mail me and I'll send it back!
- Des Markus
