Old 08-11-2004, 12:50 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
REbuild problem
hey first rebuild i ever done on my d16a6 and it fired right up..only things is it revs right to 3,000 rpms and sits there....anybody know what might this be.....
Old 08-11-2004, 12:59 PM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
could be your distributor, or your ECU, also, did you make sure your throttle cable is adjusted right(sounds stupid, but sometimes it the little things).
Ohh yeah, is it throwing any codes
KoRnSaQ
Old 08-11-2004, 01:35 PM
Shaguar47's Avatar
Shaguar47 Shaguar47 is offline
Send a message via AIM to Shaguar47
Re: REbuild problem
Yeah, always check you ecu before tinkering with anything. Saves alot time!
1990 Black Geo Storm - RIP -
1990 Blu metallic Std Hatch
1999 Milano Red Ex Coupe
Current -- Ex to Si. It's Overdone, but who gives a crap. I don't!
Old 08-11-2004, 02:01 PM
Re: REbuild problem
does it throw codes when cars on or off with the key last tick before turing on...cause its not throwing not codes...i turn key last tick beofre on lights up one red and goes off i thinking thats only to show power gowing ecu.....and yes iots not the throttle cable....think it might be the tps on the throttle body?...like soon as i crank car that thing flys right to 3,000 and sets there unless i hit throttle then goes higher....
Old 08-11-2004, 02:03 PM
4thgensvk 4thgensvk is offline
Send a message via AIM to 4thgensvk
Re: REbuild problem
check your vacuum lines
Old 08-11-2004, 02:34 PM
Shaguar47's Avatar
Re: Re: REbuild problem
The car will only throw codes when running or on the key position where all the lights on the cluster come on. If it's not throwing any codes then you should start tinkering around.
Also, check your idle screw. I may be that it somehow moved and wasn't adjusted when everything was put back together. And clean your EACV behind the throttle body. It could also be your TPS. Could be alot things really!
Old 08-11-2004, 03:22 PM
Hybrid1990crx's Avatar
Re: REbuild problem
I know if you unplug the one vacuum line that goes onto the nipple right by the throttle body, like where you can rev the motor from, if that line isn't connected then your motor will rev right up.
Old 08-11-2004, 05:14 PM
Re: REbuild problem
ok i put it where all the lights come on which last tick before on and no codes only code it used to throw was a speedo cable but i went bought a clip at honda dealer and fix that....can somebody show me a diagram on how all the vacum hoses go...i am really confused right now...also is the tps adjustable or do i got to buy a new one...?
Old 08-11-2004, 09:32 PM
Shaguar47's Avatar
Re: REbuild problem
There should be a vaccum diagram under the hood right side the emission info sticker.
Old 08-11-2004, 11:20 PM
Re: REbuild problem
anybody please help need find out what cause my motor to buzz at 3,000 rpms member this is first time break in i dont want throw a rod bearing why i cant leave car on to figure out whats causing it wanna fix it before i run into another problem
Old 08-12-2004, 02:27 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: REbuild problem
gun in mouth > pull trigger > problem solved
Old 08-12-2004, 08:44 PM
Re: REbuild problem
no need for smart commments cause you cant help me so please stay on tpic... i am really fustrated....
Old 08-13-2004, 10:18 AM
Shaguar47's Avatar
Re: REbuild problem
Check the throttle dashpot and see if the line is connected to it. It's a little round thing up above the throttle linkage.
Old 08-15-2004, 04:40 AM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
Re: REbuild problem
try to see if the idle goes down as it warms up, if not, check your throttle cable to see if it was put on too tight or check for a vacuum line that is not on all the way. 1st try what was posted above mine with the dashpot.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 08-15-2004, 06:04 AM
Re: REbuild problem
ok i try this tomorrow but i order a iacv o-ring because one that was in there was all flat and had flakes of paint...i dont know if this will cause my car to idle up to 3g though...anybody think it could cause that?
