98 Blazer hard shift
My 98 Blazer is shifting hard from 1st to 2nd and 2nd to 3rd. Runs fine on the freeway, but when I drive at slower speeds thats when it shifts hard. The Service Engine Soon lite is on. What do you think is the problem?
Re: 98 Blazer hard shift
I have the same problem, only it's not all the time. I believe it is an electrical or sensor based issue, not an actual transmission problem and here's why...: I am also having other electrical issues and they are as follows:
rear hatch release button will not operate at times, door locks trigger themselves without the key in the ignition, and with the key in the ignition. Blinker relay clicks randomly, although the blinker itself doesn't turn on unless the switch is on. All strange issues that I would be have a common problem in my case, although I haven't been able to fix it yet. If I were you before you overhaul the transmission, have your electrical system checked out in depth as possible, |
Re: Re: 98 Blazer hard shift
Mary, go to autozone and get the codes scanned for free. Get the actual code number and not the attendent's redition of it. Report back with it. |
Harsh 1-2 Upshift, SES, MIL, or CEL Illuminated, DTC P1870 Set (Replace Valve Body) #01-07-30-023B
Harsh 1-2 Upshift, SES, MIL, or CEL Illuminated, DTC P1870 Set (Replace Valve Body) 1996 Buick Roadmaster 1996 Cadillac Fleetwood 1999-2000 Cadillac Escalade 1996-2000 Chevrolet Camaro, Corvette 1996-2000 Pontiac Firebird 1996-2000 Chevrolet and GMC Light Duty Truck Models 1996-2000 Oldsmobile Bravada with 4L60-E Automatic Transmission (RPO M30) Built Prior to January 15, 2000 (Julian Date 0015) This bulletin is being revised to update VIN Breakpoint Date information and revise the Parts Information table. Please discard Corporate Bulletin Number 01-07-30-023A (Section 07 -- Transmission/Transaxle). Condition Some customers may comment on a harsh 1-2 upshift and the Check Engine Light or Service Engine Soon indicator is illuminated. Diagnosis Typically, these vehicles will have been driven more than 32,000 km (20,000 mi) before this condition occurs. The scan tool may show a DTC P1870 set as a history code. A harsh 1-2 shift or DTC P1870, caused by wear in the control valve body, may be difficult to duplicate when the transmission temperature is below 93°C (200°F). Cause The condition may be due to wear in the control valve body. This wear occurs in the bore that contains the TCC isolator and regulator valves, and results in poor, or no, TCC apply. Important DTC P1870 is a type B code. The conditions for setting the P1870 DTC must occur on TWO CONSECUTIVE TRIPS (ignition cycles, with a drive cycle) before setting a P1870 history code. When the conditions for setting DTC P1870 are met (first trip), the PCM commands maximum line pressure and harsh 1-2 shifts are the result. This may result in a harsh 1-2 shift with no history code if the conditions for setting the DTC required for the second trip are not met, on two consecutive trips (Ignition cycles, with a drive cycle). When the conditions for setting the DTC are met, on the second consecutive trip, a DTC P1870 is stored as a history code. When the P1870 code is stored, the PCM will turn on the Service Engine Soon (SES), Check Engine Light (CEL), or Malfunction Indicator Lamp (MIL). Correction Install a control valve body with the revised TCC regulator and isolator valves. Refer to the Parts Information table below. These valves are used in all transmissions produced after January 15, 2000 (Julian Date 0015), and all of the service parts currently available through GMSPO contain revised TCC regulator and isolator valves. Important If all of the following conditions are true, it is not necessary to rebuild the transmission or to replace additional transmission components beyond the control valve body. Transmission operation is normal before the transmission reaches operating temperature, or before DTC P1870 is set (no slips, flares, or missing gears). The torque converter is not blue or overheated. The transmission fluid is not burned or has no burned odor. The transmission fluid pan contains no abnormal debris (clutch material, bronze, brass, or metal fragments). Parts Information Model Year Vehicle Platform Engine (RPO) Transmission (RPO) Transmission Broadcast Code P/N 1996 S Truck 2.2L (LN2) 4L60-E (M30) SAD 24217855 1996 C Truck (Mexico) 5.7L (LO5) 4L60-E (M30) CPD 24217856 1996 C/K Truck G Van 5.0L (L30) 4L60-E (M30) CCD, CFD, KBD, WAD, WBD 24217856 1996 C/K Truck G Van 5.7L (L31) 4L60-E (M30) CHD, CJD, KCD, CMD, CUD, KPD, YDD, FFD, WCD, WHD 24217857 1996 F Car Y Car 5.7L (LT1) 4L60-E (M30) FFD, YDD 24217857 1996 D Car 5.7L (L31) 4L60-E (M30) AHD 24217857 1996 S/T Truck M/L Van 4.3L (L35) 4L60-E (M30) TBD,TAD, MSD, MDD 24217860 1996 C/K Truck G Van 4.3L (L35) 4L60-E (M30) CAD, CBD, KAD 24217861 1996 S/T Truck 4.3L (LF6) 4L60-E (M30) SHD, TLD 24217862 1996 B Car 4.3L (L99) 4L60-E (M30) BBD, BCD 24217863 1996 B Car (Includes Police Pkg.) 5.7L (LT1) 4L60-E (M30) BFD, BWD, BKD 24217864 1996 F Car 3.8L (L36) 4L60-E (M30) FCD, FBD 24217865 1997 S Truck 2.2L (LN2) 4L60-E (M30) SAD 24217866 1997 C/K Truck G Van 4.3L (L35) 4L60-E (M30) CAD, CBD, KAD 24217867 1997 S/T Truck M/L Van 4.3L (L35) 4.3L (LF6) 4L60-E (M30) SHD, TLD, TBD, TAD, MSD, MDD 24217868 1997 C Truck (Mexico) 5.7L (L31) 4L60-E (M30) CPD 24217869 1997 C/K Truck G Van 5.0L (L30) 4L60-E (M30) CCD, CFD, KBD 24217869 1997 C/K Truck G Van 5.7L (L31) 4L60-E (M30) CJD, CHD, KCD 24217870 1997 F Car Y Car 5.7L (LS1) 4L60-E (M30) FFD, YDD 24217870 1997 F Car 3.8L (L36) 4L60-E (M30) CFD, FBD 24217871 1998 C/K Truck G Van 5.7L (L31) 5.0L (L30) 4L60-E (M30) ADD, AFD, AJD, ALD, AWD, CCD, CFD, KBD, CHD, CJD, KCD 24221155 1998-2000 C/K Truck G Van S/T Truck M/L Van 4.3L (L35) 4.3L (LF6) 4L60-E (M30) TAD, MSD, CAD, CBD, KAD, WBD, SHD 24221154 1998-2000 S Truck 2.2L (LN2) 2.2L (L43) 4L60-E (M30) SAD 24221153 1998-2000 F Car 3.8L (L36) 4L60-E (M30) FBD, FCD 24221159 1998-2000 F Car Y Car 5.7L (LS1) 4L60-E (M30) FFD, YDD 24221158 1998-2000 C/K Truck (Includes Police Pkg.) G Van 5.7L (L31) 5.0L (L30) 4L60-E (M30) LHD, LSD, LUD, LPD, KXD, CPD 24221161 1999-2000 C/K Truck 4.8L (LR4) 4L60-E (M30) CCD, CFD, KBD 24221162 1999-2000 C/K Truck 5.3L (LM7) 4L60-E (M30) CJD, CHD, KCD 24221162 Parts are currently available from GMSPO. Warranty Information For vehicles repaired under warranty, use: Labor Operation Description Labor Time K6560 Valve Body - R&R or Replace Use Published Labor Operation Time |
Not good.
The 4L60-E tranny is used in several chev cars and trucks. |
Hello, I have a 98 blazer 160.000km and also the same problem, here in Caracas (tropical temperature over 35c) the transmission shifting hard 1 to 2 only if drive over highways and slow and run again, for a time, if turn off and on the engine the transmission run ok, also in cooler temperature all work fine.
Think about add any transmission cooler system (radiator) or check other valve ot activator or actuator in bad conditions?, thanks. |
Welcome to the forum. This thread is nearly 2 years old. Please start a new thread and we will be happy to help you. |
