Go Back   Automotive Forums Car Chat > Hyundai > Tiburon | Tuscani
Old 08-11-2004, 09:40 AM
cinsom cinsom is offline
check engine light
My check engine light came on in my 1997 Tiburon FX. There doesn't seem to be anything wrong wtih the car, as of now.
Does anyone know where I can reset the switch?
If there is something wrong, what can it be? what can I check? where is the PCV valve located?
Old 08-11-2004, 10:17 AM
Kat03Tib's Avatar
Kat03Tib Kat03Tib is offline
Hyundai NorCal Meets Vendor
Send a message via AIM to Kat03Tib
Did you put your gas cap on right? Sometimes that will cause a CEL. Also disconnect the battery for a few minutes and see if that helps.
________
herbalire vaporizer review
Old 08-11-2004, 10:19 AM
battery disconnect
I'll take off the gas cap and put in back on again.
Won't disconnecting the battery screw up other things?
Old 08-11-2004, 10:23 AM
Kat03Tib's Avatar
no, you will probably have to reset your clock that's all.
________
iphone jailbreak
Old 08-12-2004, 09:33 AM
tibby01 tibby01 is offline
go to autozone or something and have the code read. post the code up here and i can help you out some more.
