Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 08-11-2004, 08:35 AM
engrx2 engrx2 is offline
Question Fuel, Temperature Gauge 1992 Corolla
The fuel and temperature gauges on my 1992 Corolla go all the way up while the engine is running. I have replaced the temperature sender, checked the fuel level sender and wiring on the instrument panel everything seems to be fine.
I would appreciate any help.
Also when the engine is running the voltage goes to 14.30 volts is there a regulator somewhere to keep the voltage down to 12V.
Thanks
Old 09-14-2004, 09:45 AM
xalif xalif is offline
I had the same problem, tried several things, and it turned out to be the temperature/fuel gauge itself (in the instrument cluster/panel). I ended up buying a used instrument cluster on eBay for $15, and I swapped out the temperature/fuel gauge. (You could also take the new cluster and swap out your speedometer/odometer). It works perfectly now. I saw a 92 Toyota Corolla cluster on eBay this week:
(http://cgi.ebay.com/ebaymotors/ws/eB...category=33675); otherwise you could check a junkyard since the cluster is fairly expensive at dealers.
Old 10-13-2004, 04:48 PM
thehoot thehoot is offline
Re: Fuel, Temperature Gauge 1992 Corolla
14.30 volts is right where it should be. A fully charged battery is around 13.9V. The alternator should not put out more than 15V, if it is, then you have a regulator problem.
