Old 08-11-2004, 07:01 AM
ksvtwin ksvtwin is offline
poor gas mileage help
Thanks for helping with the front end noise. i also forgot mention i checked my gas mileage and i'm getting about 20 mpg. it's a 4 cylinder and i drive conservatively. i would have expected much better mileage. it's a '99 alero. does anyone have any thoughts about this or what i should check? Thanks in advance, Kent
Old 08-12-2004, 08:28 PM
JTrujillo86 JTrujillo86 is offline
Re: poor gas mileage help
How many miles do you have on it? Have you changed the plugs, wires, fuel filter and air filter lately? I know GM says that the plugs and wires can go until 100K miles, but I plan to do mine at 60K miles. The air filter could be playing a huge roll in this problem if it hasn't been changed in a while. Also, have you ever had a fuel induction service on the car? It's about $120 at the stealership. They clean the injectors and service the throttle body. This helped with my 3.1L Malibu I used to have. I would look into it.
JeReMy
Old 08-13-2004, 07:17 AM
The car has 60,000 on it and i just bought it. yea, maybe you're right...it just needs a good tune up and air filter. i will check those things right away. particularly the air filter and plugs. i think on fuel injection, it compensates for a clogged filter though and that doesn't affect your gas mileage the way a clogged filter on a carb would. at least it seems that would be the case. doesn't matter though...if it's clogged , it needs to be changed and i will check those things. thanks for the advice.
Old 08-13-2004, 11:04 AM
If your filter is clogged or has been clogged, there is a good chance your injectors don't look too good either.
Let me know how things turn out after you check that air filter.
Jeremy
Old 08-13-2004, 11:06 AM
Also, if you don't want to replace the plugs you can have them cleaned and re-gapped. If I were you, I would check the gap and clean them before you replace them.
Jeremy
Old 08-13-2004, 11:10 AM
Thank you, i will check these things tomorrow. hope the plugs are easy to get to!
Old 08-13-2004, 05:35 PM
The plugs on the 2.4L are extremely easy to get to. Just take off the black cover that says "2.4L". The plugs are right under that.
Jeremy
Old 02-04-2005, 01:29 PM
roryGhrame roryGhrame is offline
Re: Re: poor gas mileage help
I have a 2000 Alero, standard 5 speed, 4 cylinder 2.4 twin cam.
I am Horrible with math.. and so could someone check my milage and see if this is correct.
I recorded recently my fuel consumption as such;
423 km/42 liters = 10.07 km/L
= 22.96 KM/Gallon
or
= 14 miles/Gallon?
Is this correct? I'm canadian so we dont work in Gallons or miles too often but I want to check my milage against the standards laid out by Aero owners in this forum.
If I'm correct than it would seem I'm getting horrible mileage. But I suspect my math is wrong. P.S. Not reading alot of good things about the alero but i just boguth mine and it seems to run perfect - gas milage aside.
please help...
