Old 08-11-2004, 05:32 AM
3000Star 3000Star is offline
Send a message via AIM to 3000Star Send a message via Yahoo to 3000Star
Question harness ?
my stock seatbelt doesnt completly retrack and it bugs me so i was just thinking about geting a 3 or 4 point harness... but i had one question. can you put a harness on a stock seat and how do you do it.. is there any drilling needed?
Old 08-11-2004, 03:20 PM
StealthModifier StealthModifier is offline
Re: harness ?
My seat belt does the same thing
Old 08-11-2004, 03:43 PM
sLADe781 sLADe781 is offline
Re: harness ?
Mine does too. :o/
Old 08-11-2004, 10:08 PM
Re: harness ?
they should recall that shit so i can get one that works.lol
Old 08-11-2004, 10:27 PM
Re: harness ?
lol, sometimes mine doesnt retract at all.. just drops in my lap
Old 08-11-2004, 10:38 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Wow mine works fine, didn't knwo that was a problem. Sounds like an easy fix though, just some mechanical tweaking.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 08-11-2004, 10:45 PM
Re: harness ?
that would be fun
Old 08-12-2004, 07:18 AM
BB1970's Avatar
BB1970 BB1970 is offline
Re: harness ?
when you say it doesn't retract i take you mean it is slow going back into itself? if it is you should try spraying a good quality silicone spray on the back and front of the seatbelt material i.e the strap as they get dirty and stick on themselves hence it not going back properly.
i had the same trouble but mine work perfectly now.
best thing to use is a dashboard interior cleaner which has high silicone properties NOT a foam acting cleaner. i think you guys have Armorall in the U.S. dont you? thats a good one to try. spray it on and pull the belt in and out of itself until it becomes smooth and free of sticking.
give it a go you will be suprised how much of a difference it makes.
brian.
1993 Mitsubishi GTO Twin Turbo (RHD) NOW SOLD!!!
9b turbos with manual boost valve mod set @14psi
turbo xs type h-rfl blow off valve
blitz dome filter
sachs clutch
completely de-catted
fuel pump voltage rewire mod
ebc redstuff front brake pads
greddy fully automatic turbo timer
now drives a sensible family sedan. A 340hp 1997 mitsubishi evolution IV
Old 08-12-2004, 04:02 PM
Thourun's Avatar
I jsut hate how far back the seatbelt is, and i'm not terribly short or anything (5'11").
1995 3000GT VR-4
Old 08-12-2004, 07:59 PM
Re: harness ?
I think it has to do with the angle of the way it goes in too.. cuz when mine doesnt go in.. ill undo it from my seat and let it pull in straght.. it goes in a little better but i have to pull it in back and forth
Old 08-13-2004, 12:29 AM
3000gtkid 3000gtkid is offline
Send a message via Yahoo to 3000gtkid
Re: harness ?
mine does that to sometimes and i hate it. but the harrness should go in easy and as long as you could find a good bolt to hook them to then you do not have to drill anything
Old 08-13-2004, 12:37 AM
Re: harness ?
what would u have to drill?
Old 08-13-2004, 12:43 AM
Re: harness ?
you would just have to drill a hole to hold the end of the belts down
but you have to put those kind of belts at a right angle or they could break your back in a wreck
Old 08-13-2004, 03:47 PM
kbkura kbkura is offline
Re: harness ?
That sounds like a pretty common problem. Luckily, mine doesn't have that problem. Unluckily, my car doesn't run right now. *Stupid timing belt/bent valves...
Old 08-13-2004, 06:55 PM
Re: harness ?
hey, well at least ur seatbelt is fine j/p
