A/C Is blowing hot air.......
It's like the heater is on. What could be the problem?
Re: A/C Is blowing hot air.......
Check for leaks and recharge the system. Make sure your compressor is working as well. I'm not great with A/C so its kind of hard to diagnose without looking into it. But I'd say you have a leak and lost all your freon.
1969 Cougar 357w & TKO - 475hp |
you could by pass the low preasure cut off switch on the drier. if the a/c clutch clicks on then most likely its low on freon . a small jumper wire between the terminals on the plug to the switch is all you need
