Go Back   Automotive Forums Car Chat > Toyota > MR2/MR-S
Old 08-10-2004, 11:39 PM
Stevomr2Turbo Stevomr2Turbo is offline
13's what do i need?
hey all.. my goal is fairly easy. i'm just wanting to b able to run 13's consistant. I havn't run it at the track yet, so i dunno what its runnin right know. i have a 91mr2Turbo.. all i have right know is a Apexi intake and a blitz dtt, which said i'm runnin 9.1psi. What is a good route to go? i'd like a tko dp and exhaust. but i dont' have th money right know. so i could just get the tko exhaust. I oculd also get a fcd and mbc and boost say 13psi. Also at this level, would alcohol/water injection b an bad idea? thanks alot, steve
Old 08-11-2004, 05:36 AM
JekylandHyde's Avatar
JekylandHyde JekylandHyde is offline
AF - Advisor
Re: 13's what do i need?
As long as your car is healthy and your ignition pieces are fresh (Toyota Cap, Rotor & Wires ... good copper plugs), there is no reason you can not buy a MBC and run 15 psi.
You do not need to buy a FCD, although they are a good idea. You can get rid of FC for free, but then you will have NONE. The FCD allows you to raise the FC point.
Intake, exhaust, downpipe and 15 psi should be plenty to run 13s with good driving.
Water injection is good idea for turbos regardless of mod level.
Sponsorship: Amateur Motorsports <-- Get the book! - books are now available for shipment
Old 08-15-2004, 10:43 AM
200SXGTi-R 200SXGTi-R is offline
how to get rid of FC? i forget
Old 08-15-2004, 01:36 PM
MR2Driver's Avatar
MR2Driver MR2Driver is offline
With a FCD (you can make one with radioshack parts)
http://toymr2.tripod.com/fcd.html
Old 08-15-2004, 03:22 PM
AF - Advisor
You can 100% eliminate fuel cut by corking the vac line to the OEM map sensor next to the little 'diagnostic' box in the engine bay.
You will 100% eliminate fuel cut and also lose the function of your OEM boost gauge.
Old 08-16-2004, 12:03 AM
MR2Driver's Avatar
Lose the function of the OEM gauge?!? But its so useful!!!!!!!!??!?!??!
