Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 08-10-2004, 09:34 PM
woundedknee woundedknee is offline
2001 w/coolant leak at intake manifold
Got a 2001 SLE which is showing signs of a coolant leak out of the bottom front driver-side of the intake manifold. I know there were problems in the past (98-99) with plastic manifolds.
Does the 2001 still have the plastic manifold?
Anyone else see this?
Thanks
Old 08-19-2004, 06:57 AM
markwb's Avatar
markwb markwb is offline
Re: 2001 w/coolant leak at intake manifold
The 2001 Bonnevilles do have the composite material (plastic) upper intakes. Check the area around the throttle body to upper intake junction. There is a gasket there, check it with an inspection mirror.
Mark
2003 Pontiac Bonneville SSEi, 1999 Ford Escort SE, 5 Speed
IBEW Local 261 Groton, CT
Old 08-20-2004, 04:01 PM
Thanks Mark. I'll check it out.
Nice bonnie! Factory color?
WN
Old 08-21-2004, 07:36 PM
markwb's Avatar
Thanks, the color is Maple Red Metallic, and it is factory.
Mark
Old 09-21-2006, 10:19 AM
SatchBoogie SatchBoogie is offline
Thanks
On my mom's 2002, i already had to replace the stupid plenum(plastic molding) because there was a coolant leak. You might want to look into that if its cracked anywhere. It's quite a job, but you will save a lot on labor.
Old 09-24-2006, 06:32 PM
auto trainy auto trainy is offline
Pressure test the cooling system to be sure its the plenum and not the lower intake manifold gasket,there were some issues with those also,I wouldn't want to put on a plenum and have to do the job over for a lower intake gasket,Good Luck
Old 09-26-2006, 06:10 AM
jdq jdq is offline
Either way do the lower anyways while your in there.
2000 bonn ssei 155000 klm
1997 dodge caravan 92000 klm
