Old 08-10-2004, 06:00 PM
Blk89CrxSi Blk89CrxSi is offline
Send a message via AIM to Blk89CrxSi
TPS adjusting
I have a 89 crx si and it has a rough idle. The tach bounces from 1000 to 500 during idle. I think it's my tps sensor which i had to replace since my oringal was shot. I know the volt at closed throttle has to be .5v but which wire on the tps harness to i piggyback into to read the volts. As far as I know wot is 4.5 volts, but not exactly sure. My car does have the d16z6 in it and I duno if that'll make a difference or not.
Old 08-11-2004, 03:48 AM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
Re: TPS adjusting
last time i checked voltage, i think i tapped into the middle wire.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 08-11-2004, 06:42 AM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
Re: TPS adjusting
I'm a firm believer that in order to fix a TPS, you go to a wreckers, pick up a new throttle body with an untampered TPS on it and bolt it on as a unit. I've had to do it once and haven't looked back. The reason a TPS is factory sealed is so that it isn't tampered with.
Cheers
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 08-11-2004, 08:19 AM
I would like to just go out and get the whole throttle body, but don't have enough money. I'll try the middle wire and adjust from there
Old 08-11-2004, 05:10 PM
Mojoe Mojoe is offline
Re: TPS adjusting
green=ground Attach DVM Negative lead
yellow=constant 5v
red=signal (0-5v) Attach DVM Positive lead
