Go Back   Automotive Forums Car Chat > Honda > CL | Inspire | Saber | TL
Old 08-10-2004, 12:20 PM
PontiacDanny PontiacDanny is offline
Unhappy 2001 Acura 3.2TL Erratic RPM Problem
Hi there, I just purchased a 2001 Acura 3.2TL the car has 81K Miles. Seems to be in good condition but she has a problem. After the car is left on for 5 minutes The RPM's start jumping up and down between 1000 to 2000. The check engine is also ON.
I would greatly appreciate if any one with info on this matter can help... thanks
Old 08-15-2004, 10:20 AM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
Re: 2001 Acura 3.2TL Erratic RPM Problem
most likely your EGR....i work with acura and we have that all the time. Take it to the dealership and have them check it out.
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
Old 11-29-2004, 07:14 PM
stubbornmike stubbornmike is offline
These 3.2 have small egr ports they become clogged easily. The dealer sells a cleaner to run through the air intake & egr ports after egr is removed.
