Go Back   Automotive Forums Car Chat > Toyota > IS200/IS300/IS350/Altezza
Old 08-09-2004, 09:17 PM
Indetrucks's Avatar
Indetrucks Indetrucks is offline
Unhappy Auto Adjust Headlight Warning light on Dash.. Help!!
The only problem that resulted from lowering my girlfriends IS300 was the auto headlight adjust warning light came on the dash. Obviously the lowering of the car effected the sensor somehow. I have seen many Lexus's lowered with coil overs and was wondering what the adjustment is out there to fix this light. Everything works fine but that little light is on. (It's the light that is related to the headlights adjusting up or down when your on a slant or decline).
Christian
62 Nova Pro Street BB
64 Lincoln Continental
65 Chevelle SS BB
72/01 Mini Cooper (Classic)
02 Ducati 998 Mono SuperBike
[I want you to remember that no bastard ever won a war by dying for his country. He won it by making the other poor dumb bastard die for his country…]
Old 08-19-2004, 11:21 AM
DL72 DL72 is offline
The lights are working but are probably shooting up like high beams. Look on the passenger side right under where the control arm is. You'll see a metal/silver color little rod that should be vertical but was probably put back horizontally. If so, go back to the shop that did the install and have them fix it and the problem should be fine. The other one is located in the wheel well of the front driver side tire.
Old 08-19-2004, 12:36 PM
Indetrucks's Avatar
Re: Auto Adjust Headlight Warning light on Dash.. Help!!
Ok, thanks for the tip. I will check out the car today after work and let you know what I find. So did these/this rod get bumped during the lowering or does it just need to be calibrated to where the ride height is on the car now?
Christian
65 Chevelle SS BB
Old 08-19-2004, 02:23 PM
No, when the shop re-installed everything it's a common mistake to install them horizontally instead of vertically. Had it happen on my car also when I had my coil-overs installed.
Old 08-19-2004, 03:29 PM
Indetrucks's Avatar
Oh I gotcha, Crazy how a rod that is supposed to be vertical can still be installed horizontal. Anyway, thanks and I'll keep ya posted.
Christian
65 Chevelle SS BB
