Old 08-09-2004, 05:35 PM
jstbecauz jstbecauz is offline
2000 3.8 Camaro, no acceleration with WOT
So here goes. I have a 2000 camaro with a 3.8 and a manual transmission. When I drive it normally or about 3/4 WOT it will rev all the way through to the limiter. If I hammer on it WOT it will stop producing power at about 4000rpms. I can turn no more rpms. It will do the same thing if I am sitting still and just reving it. I checked/replaced the fuel filter, I removed the cat's, checked the fuel pressure, the MAP sensor, the EGR valve and the MAF sensor. I checked and tested the clutch anticipate switch and that appears to be operating properly as well. I had another ICM that I tried with no success either. The only thing that I can think of next would be a PCM. Anyone else have this type of situation that may be able to shed some light on the topic?
Thanks in advance!
-jstbecauz
Old 08-09-2004, 07:11 PM
Lotus49 Lotus49 is offline
Send a message via Yahoo to Lotus49
plugs, wires, distribuator.. any of thoes can do it
Old 08-10-2004, 06:53 AM
None of these are the culprits, it is distributorless ignition too.
Old 08-10-2004, 07:54 AM
LT1MAN LT1MAN is offline
Banned
Re: 2000 3.8 Camaro, no acceleration with WOT
i had a similar problem in my z, it would skip intermittently and when it got really hot outside it was real bad and i replaced a whole bunch of shit and what did the trick was the distributor, the distributor was firing to all 8 but it had a short in it or something and it was arking and all inside the housing was all burned up. check into that
Old 08-10-2004, 09:52 AM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
LT1MAN, look one post above, he dosnt have a distributor
when you floor it does your check engine light come on??? have you had it run for codes anyway?? did you used to be able to floor it past 4k and just recently it wont do it anymore?
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 01-30-2005, 01:14 PM
LS1MAN LS1MAN is offline
Banned
Send a message via AIM to LS1MAN Send a message via Yahoo to LS1MAN
If its not producing enough power, you probably need a V8.
Old 01-30-2005, 02:48 PM
Xenostalgia's Avatar
Xenostalgia Xenostalgia is offline
Send a message via AIM to Xenostalgia
Re: Re: 2000 3.8 Camaro, no acceleration with WOT
No offense LS1Man maybe we should help him with his current problem and not bag on him for his choice of Maro. To each his own.
Originally Posted by 97CamaroRS
You know he's cruisin in the GN above us - RIP, Andy
Be Warned....
Originally Posted by twospirits
what your name really means...
XENO...
Xtreme
Emotional
Neurotic
Ominous
www.Xenostalgia.com Exit your Reality || 97 Acura Integra GS 2DR
Old 01-31-2005, 09:12 AM
Banned
then there should be a separate forum for v8 camaros and v6 camaros
Old 01-31-2005, 10:06 AM
Banned
oh yeah, its a 2000, im dislexick so i didn't quite get that far considering i started at the end.
Old 01-31-2005, 10:08 AM
Banned
yeah LS1MAN, shame on you!
