Old 08-09-2004, 04:07 PM
americanmuscleman americanmuscleman is offline
Send a message via AIM to americanmuscleman
Question quick little question about gt 40
sorry i just have a question about fujimis gt40 the black one. is this model good to build and does it have good engine detail cause i wanna build one. thanks
Old 08-09-2004, 04:37 PM
racer917's Avatar
racer917 racer917 is offline
Love this kit, there may be other gt40s with engine detail but not this one, except for what you see from the rear pe grille, comes with real seat belts and a sheet of pe parts with amazing grilles. If the decals are not by cartograf then you'll need to paint or add white decal films beneath the number decals which are soooooo thin, that' what I did. Also I'm using the S27 pe sheet which adds so much but is so easy to use. I should have mine built and have some pics in 3-4 weeks, I don't have much time to build anymore. Go ahead and try it.
Old 08-09-2004, 10:55 PM
how many pieces make up the engine? also, doesent the hole back come as a seperate piece from the front? if this is so then cant u lift the back off to see in there?
Old 08-09-2004, 11:00 PM
krebs128 krebs128 is offline
Send a message via AIM to krebs128
Re: quick little question about gt 40
racer said there wasn't an engine, so zero pieces make up the engine.
Old 08-10-2004, 10:19 AM
ok thanks maybe ill take some of my scrap parts and try to build an engine.
Old 08-10-2004, 10:23 AM
racer917's Avatar
Actually what you see from the rear is I believe the gearbox which is molded to another large piece (?) in one piece, and when done right looks just fine. You see only what you see in the actual car. The body is in one piece. Again, I belive there are others by Fujimi with the split body. If you wanted to split to body you have to add an engine. I know there is a resin upgrade for this car but a lot of $$.
Old 08-10-2004, 10:27 AM
Vric's Avatar
Vric Vric is offline
Talking of Resin Engine, RallyRaider is working on a GT-40 with this resine Engine
http://www.automotiveforums.com/vbul...d.php?t=270204
There is also a Full Resin Kit of this car with engine from Lemans Miniature (which is awersome)
Old 08-10-2004, 12:18 PM
thanks for all the replies. what i think im gonna do is cut the body into 2 pieces and then make and engine out of some scrap pieces. the only reason i will go through this is because the engine is my favorite part of the car to build
Old 08-11-2004, 05:30 AM
RallyRaider's Avatar
Zomby Woof
Muscles, do you have the kit already? Because the "black one" sounds like the 1966 LM winning Mk II. It has the engine cover molded in. The various Fujimi Mk I kits (like the Gulf car above) have the rear already seperate. You might want to plum for one of those instead.
As stated by others, neither Fujimi kits have engine detail. If you want a resin engine transkit try Strada Sports, here is the link:
http://gallery.bcentral.com/GID50824...nsion-kit.aspx
Although this engine is not strictly suitable for all GT40s and will require considerable scratchbuilding of the suspension and chassis.
Old 08-11-2004, 11:42 AM
no i dont have this kit yet but it will probally be my next one after i finish my f40. i want either the black with white stripes or red with white stripes kit cause i think they look the best. ya the resin engine would be nice but my wallet says no cause i earn my living cutting grass. (lol $30 a week)
