Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 08-09-2004, 04:44 PM
crabby760 crabby760 is offline
b18c1 header on b16a?
will a b18c1 gsr hp racing header fit on my b16a motor?
curious a friend has this racing header and doesnt want it anymore im curious if there will be any issues making it fit on my b16a motor?
Old 08-09-2004, 10:40 PM
91civicDXdude's Avatar
Re: b18c1 header on b16a?
b16a has a shorter deck height, so the header will typically extend downward below the oil pan a little further than on the B18C, but it will work.
Old 08-10-2004, 12:39 AM
ok cool... but a b16a header wont fit on a b18c or b18b motor rite?
and do u think since the hp racing header is for a 1.8 vtec it might be bigger for more FLOW? or the same as the 1.6 vtec one?
Old 08-10-2004, 06:06 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Repost>repost>repost.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 08-11-2004, 02:01 PM
boosted k20's Avatar
boosted k20 boosted k20 is offline
it will bolt up to the head with no problem, but im not sure if it will bolt right up to the Cat. U might need to do some custom work for it to connect to the cat. But once again im not too sure if it will bolt right up to the cat
www.MEDIUMRACING.com
Old 10-13-2004, 03:47 AM
will a b18c1 gsr header fit on a b18b1 ls motor? thanks in advance
i know it will bolt to the head but will it clear the block and oil pan and bolt to the cat?
Old 10-13-2004, 10:25 AM
it will bolt to the head, clear the oil pan but it will not bolt onto the cat. u need to do some custom fitting to make it fit
Old 10-13-2004, 12:03 PM
why wouldnt it fit to the cat? if u dont mind me askin the cat i have is a gsr cat and gsr exhaust...
my car is a 96 gs-r but has a b18b1 ls motor.... so wouldnt the gsr header bolt up perfect
Old 10-14-2004, 09:03 AM
i think the header is too long or too short. ur gonna need to do some custome welding for it to fit
Old 10-15-2004, 11:59 AM
AF - Advisor
You know or you think?
Anyways, bolted up fine for me. The header will sit lower, but, shouldnt be an issue if your not dropped too low.
b18 header to b16 will be fine.
b16 header to b18 will bring clearance issues.
Old 10-19-2004, 01:10 PM
my car is a 96 integra gsr but it has a 98 b18b1 LS engine and the cat is gsr will a gsr header fit rite?
