Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 08-09-2004, 02:58 PM
GEdge GEdge is offline
1997 Ranger 4.0 Heavy Idle Surge
1997 Ranger just started surging from about 200 to 1500 RPMs at idle. After running for a while (10-15 minutes) the surge settles into a range of about 600-1200 RPMs. It is significantly worse at start up if the AC is switched on, but little different after running for a while. Suggestions?
Old 08-09-2004, 03:09 PM
fordfury94's Avatar
fordfury94 fordfury94 is offline
Send a message via AIM to fordfury94
Re: 1997 Ranger 4.0 Heavy Idle Surge
Ive had the same crap. check/clean/replace youre IAC.
If that dont work, clean youre MAF and check your IAT.
The reason its worse when A/C is on at startup is the compressor is pumping. that can even cause youre truck to cut off. just wait till everythings warmed up to turn that on.
------------94 Ranger XLT 4x4-------------
-Cold air intake system
-flowmaster 40
-Apten Chip
-other "free" mods
~clear corners
~completely clear tails w/ red covers
~billet grill
~pilot fogs
~painted interior
~alot of Ford Racing accessories
Old 08-10-2004, 07:00 AM
95silverado 95silverado is offline
Clean the throttle body. Carbon can build up on the throttle plate and cause idle problems.
Old 08-10-2004, 09:30 AM
I have cleaned the IAC valve and this appears to have solved the problem. When I removed the air intake "hose" a sticker appeared on the end of the throttle body warning me not to clean it as it has a special coating. I wiped out the carbon, but did not apply any cleaner or detergent. Is there a recommended cleaning solution for the throttle body?
Old 08-10-2004, 11:26 AM
I don't know if throttle body cleaner would be safe for your truck or not. I know you can't use carburator cleaner.
Old 09-01-2004, 06:28 AM
1994RangerMan 1994RangerMan is offline
where is the IAC located on a 94 ford ranger?? cuz my truck reves up to about 2000 rpm's when it first starts and then drops down to 400, almost stalling out, then back up again, and so on and so forth. would that bed the same problem... ???
Old 12-21-2005, 04:30 PM
ggreene1 ggreene1 is offline
Ranger Idle problems
I also have an idle surge proble but not as drastic as 400 to 2000.. maybe up to 900 and then sometimes dies. If IAC is idle air control, I already replaced it... The problem didn't go away. Now here is the wierd part. The truck (97 Ranger w/ 4.0 liter) idles perfectly if the tank is full. Then at about 2/3 to maybe 1/2 it starts the surging... Any thoughts ???
Thanks
Old 12-21-2005, 09:21 PM
Crasen Crasen is offline
Re: Re: 1997 Ranger 4.0 Heavy Idle Surge
The IAC valve is going to be just behind the throttle plate. It will have an electrical connector on it. Do not confuse it with the Throttle Positioning Sensor. If you are not sure which one it is have someone turn the key to the run position while you listen for it to move. You can ussually hear it run when you do that
Old 12-22-2005, 11:35 AM
Re: Ranger Idle problems
Vacuum leaks seem to be a common source of this problem. Fuel cap, fuel lines, etc. Turned out I finally found my vaccuum leak to be at the Intake Plenum manifold gasket.
Old 12-22-2005, 04:06 PM
Re: Re: Ranger Idle problems
Yes a vacuum leak can cause the same problem, after all an IAC valve is basically a controlled vacuum leak and when it malfunctions becomes an uncontrolled vacuum leak by allowing air to bypass the throttle plates
Old 12-22-2005, 05:56 PM
Re: Re: Re: Ranger Idle problems
Hey should I put any kind of sealer on the gasket of the IAC ??
Old 12-23-2005, 05:10 AM
Re: Re: Re: Re: Ranger Idle problems
If you have a gasket... That is your seal. If you need to hold the Gasket in place for installation you can use a gasket adhesive.
