Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 08-09-2004, 11:31 AM
cwilson cwilson is offline
Oil Pressure
I would like to hear what other peoples oil pressure runs at.
After engine is warm, mine runs at only about 15 p.s.i. when idling, and then comes up from there when accelerating. 15 p.s.i. seems low to me - even at idle.....any thoughts?
Old 08-09-2004, 12:13 PM
Sweet William's Avatar
Sweet William Sweet William is offline
Both my 95's (128k &112k) usualy run around 13psi hot at idle. I posted this same thing a while back, but I think it is read interesting so here it is again...
The wrong viscosity oil can cause a problem also. These motors run hot and viscosity is affected more at temp. extremes.
This is something from bbobynski form another forum about oil pressure. He was an engineer on the Northstar project so I tend to beleive what he says...
"A perfectly good Northstar will idle with 5 PSI oil pressure when it is smoking hot with smoking hot oil.....
Oil pressure is greatly over rated....LOL.... The engine just needs enough oil pressure to deliver oil to the center line of the crank to lube the rod bearings. The minimum oil pressure required is determined by the diameter of the main bearings and the RPM. The oil has to overcome centripital force to reach the center of the crank...that is what oil pressure is for.
Most engines , including the Northstar, will idle with little or no oil pressure. The load on the bearings is so low and the RPM is so low that very little oil flow is needed. Excess oil pressure just takes more energy and fuel....costing fuel economy.
The oil pressure of the Northstar was a bit of a crap shoot when it was being designed and developed. With the expansion of all aluminum main bearing bulkheads and an all aluminum engine and 32 hydraulic tappets there was some consternation about how much oil flow and pump capacity was required...esecially as the engine aged and wore with miles. The pump on the 93 Northstars was pretty big and flowed a lot of oil...even with the large capacity pump , though, the idle oil pressure with the engine smoking hot (like 300 degree oil and 265 degree coolant in Death Valley after pullling a trailer to the top of the pass flat out....LOL) would often be 4-5 PSI. No prob.
As experience was gained with the engine in development and in testing we realized that the oil pump was on the large size for what it needed to be and was costing efficiency and moving a lot of oil around unnecessarily. In 96 the pump was downsized to be closer so as to pump less oil....and improve efficiency.
People are enamored with high flow oil pumps and high oil pressure but it really isn't nescessary. Even the sand rail guys that are spinning the engine 7000 and 8000 RPM use the standard oil pump with no problems. The only issue they have with oiling and bearing problems is climbing hills so steep at max RPM that the pickup sucks air and starves the system...so they run a pressurized oiler system to "make up" oil flow when the pickup sucks air and/or dry sump the sytem. "
Old 08-09-2004, 01:43 PM
Marc_Aurora_2001's Avatar
Marc_Aurora_2001 Marc_Aurora_2001 is offline
My 2001 4.0 starts cold with around 69 lbs.,
and when warmed up, runs at 12 - 15 lbs.
_______________
GM!!! BRING BACK OLDS!!!
Old 08-13-2004, 04:18 PM
RoraStar96's Avatar
RoraStar96 RoraStar96 is offline
Send a message via AIM to RoraStar96 Send a message via MSN to RoraStar96 Send a message via Yahoo to RoraStar96
Re: Oil Pressure
I get no less then 5 PSI at idle when the engine is at operating temp, I have seen over 15 psi at accel.
1997 Aurora
"Aurora Snow"
250++HP 4.0L Modified Aurora V8 w/Autobahn Performance
On Deck: RSM intake, RSM 80mm TB
Administrator, www.oldsmobileforums.com
Administrator,Aurora Club of North America
Administrator, www.bonnevilleclub.com
Adminstrator, www.ontariobonnevilleclub.com Coming Soon
Old 08-15-2004, 11:15 PM
anusemoon83 anusemoon83 is offline
Re: Oil Pressure
at idle i get around 15psi but on highway 70mph i get around 60psi :S
Old 08-18-2004, 04:35 AM
kev's 96 Aurora's Avatar
kev's 96 Aurora kev's 96 Aurora is offline
Send a message via AIM to kev's 96 Aurora Send a message via Yahoo to kev's 96 Aurora
at hot idle I have low 20's and at hot cruising 70mph I get low 50's. Until I hit around 200 degrees though I have seen it say 65 to 70. I wonder if this is correct.
Just got a '96 Aurora
89k miles
Mods: Airbox, 20% tint
Very powerful car.
Old 08-18-2004, 09:54 AM
BigDaddy Royster's Avatar
BigDaddy Royster BigDaddy Royster is offline
Re: Oil Pressure
I idle at around 15psi and on the open highway I get around 60psi crusing at 70mph on my RORA.
95 Olds Aurora (Northstar 4.0L w/Autobahn Package @ 250+ HP)
98 Olds Bravada (4.3 Vortec)
95 BMW 740 i (salvage purchased from insurance co. to be fixed up)
Check out other pictures of my RoRa at WWW.CarDomain.COM
BigDaddy Royster
Old 08-18-2004, 01:39 PM
I have a correction to make to my prior post.
When I mentioned running at 12 - 15 lbs., I
should have said 12 - 15 lbs. at idle. On the
highway, at 65 -70 mph, the pressure is about
65 lbs.
_____________
Old 08-19-2004, 09:07 PM
treeboy38's Avatar
treeboy38 treeboy38 is offline
Re: Oil Pressure
My 97 gets around 60 psi when I turned the car on. While driving in town it changed between 55-60 psi. Does that mean there is something wrong?
1997 Burgandy Aurora
Old 08-20-2004, 11:56 AM
rodtice's Avatar
rodtice rodtice is offline
Re: Oil Pressure
nope, thats not really high.
