Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 08-09-2004, 11:24 AM
gp893 gp893 is offline
99 Automatic trany service
Hello, i changed the fluid, and the owner manual says to add 1.7 qt. so i did. But after driving it for 10 mins, and re checking the level - it was at the cool level.
So should i add 1 more qt?
What's the diffrance between ckecking the fluid level in cold or hot condition?
Old 08-09-2004, 01:15 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 99 Automatic trany service
Add enough to bring it to the hot level after having driven it that far. May not be 1 qt.
"What's the diffrance between ckecking the fluid level in cold or hot condition?"
The ATF expands from heating and the level rises.
Old 08-09-2004, 01:24 PM
Smile
Thanks again brain r.
Old 08-09-2004, 01:44 PM
Thumbs up
Hi Brian R.
Do u have info on a 2003 G-35 5S Auto, Sadan?
Old 08-09-2004, 02:40 PM
Brian R.'s Avatar
Resident Chemist
What kind of information?
BTW, driving for 10 min may not be long enough, particularly in winter. Depends alot on how much you work your torque converter. I would check the ATF level after having driven it in low speed or stop-and-go traffic for longer than that. There is no hard and fast rule that I know of. Driving it on the expressway is easy on the torque converter because it locks up and doesn't have to work at all above 50 mph.
Also, dropping the pan and replacing the 2 qts or so of fluid doesn't change most of the ATF. A dissassembled transmission holds 15 qts of ATF, so you can see how little is really changed by dropping the pan. The majority of the fluid is not in the pan, but in the torque converter and the valve body. To change most of the fluid, you have to flush the transmission through the transmission cooler lines with a special flush machine.
http://www.gadgetonline.com/TransFlush.htm
Old 08-09-2004, 04:41 PM
last year i installed a trans cooler, maybe that's why i need to add more ATF.
Old 08-09-2004, 05:54 PM
i see your point, thanks again
Old 08-28-2004, 03:05 PM
Originally Posted by gp893
Hi Brian R.
Hi
Does the a/c cpmressor work all the time in a 2003 g-35, even when i set the temp to 75 in the cabin.
also the contor panel of the a/c acts weird, when i press econo-the fresh air light come on too.
do u have any info about that
Thanks
Old 08-28-2004, 11:14 PM
Brian R.'s Avatar
Resident Chemist
Sorry, I don't know anything about that car. Try the appropriate forum.
Old 08-29-2004, 11:11 AM
Re: Re: 99 Automatic trany service
Thanks
i'll try that
