Mazda Millenia S TCS light Fix !
Hello All U Miserable Mazda Millenia Owners !
I have seen the light ! "No pun intended" I took my 95 Millenia S back to the dealer for the second time after having 2 other shops troubleshoot the problem for about a year and a half. We told them to keep it until they fixed the problem. They had the Mazda engineers on the phone several times. They were baffled! Once we informed them that we had to have a water pump and timing belt replaced (at a different shop) they found the problem. The morons at the other shop did not reconnect the vacuum hose back to the vacuum pump. It runs like new now! So, if you have had this type of work done on your Millenia or in that area of the engine, you may want to have your shop check for a disconnecte hose. (NOTE: I also found out that a split hose, a cracked or disconnected T-connector will cause the same problem, therefore it may be advisable to take it to the Mazda dealer to check the whole vacuum system. Especially since on the "S" there is a maze of hoses throughout the engine. The mechanic will need the proper vacuum schematics to troubleshoot any problem with the vacuum system.
Good Luck
